GT28RS: What amounts of PSi can it push, how do you control the internal wastegate?
I really hate even ask this, but I have been looking alot. I have a 95 coupe with an LS swap with a Turbonetics T3/T4 currently. I would really like to get the disco potato, just due to the great streetability it seems to bring.
Any links or help from gurus will be greatly appreciated.
Re: GT28RS: What amounts of PSi can it push, how do you control the internal wastegate? (B_Somethin
If you're running a t3/t4, i'd opt for the atpturbo.com gt28rs "t3/t4" drop-in option. That is unless you plan to swap manifolds & downpipes. You could block of your external gate and run the internal. An internal gate is no more complicated than an external being that it needs a vaccuum source to open up. You'd need to ask which size spring your internal gate is though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RacerXI »</TD></TR><TR><TD CLASS="quote">If you're running a t3/t4, i'd opt for the atpturbo.com gt28rs "t3/t4" drop-in option. That is unless you plan to swap manifolds & downpipes. You could block of your external gate and run the internal. An internal gate is no more complicated than an external being that it needs a vaccuum source to open up. You'd need to ask which size spring your internal gate is though. </TD></TR></TABLE>
the only worry i have with an internal wg on the gt28rs is, you cannot clock the turbo without affect the internal wg positioning.
Thanks for the input guys, anyone else?
elpiar
07-16-2005 05:08 AM
