need some help on tuning meth
Old Jul 25, 2005 | 04:14 AM
slowgti's Avatar
Default need some help on tuning meth
i'm in the process of building a drag vw and would like to see if anyone on here has any experience on tuning a meth burning setup. my setup is a 2.0 16v, rods and pistons, comp ratio is 9.5 to 1. with a redline of 9500 rpm. looking for somewhere around 600whp. fuel system consists of a areomotive a1000 pump and matching regulator with -8 feed and -6 return lines. i was thinking that an 8 pack of 830cc injectors would be enough to keep it fed at my power level on meth. any insight or setup tips would be greatly appriciated. thanks, joel
Old Jul 25, 2005 | 05:29 AM
tony1's Avatar
Default Re: need some help on tuning meth (slowgti)
8 880cc injectors will barely be enough fuel for 600whp, put something bigger in it. We run 8 1600's on the race cars and we're still almost out of fuel. I'm not sure that pump you have will flow enough either. Make sure you put a fuel pressure gauge on it so you can keep an eye on fuel pressure on the dyno, to make sure it's maintaining.
Old Jul 25, 2005 | 06:34 AM
Drag_On's Avatar
Default Re: need some help on tuning meth (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">8 880cc injectors will barely be enough fuel for 600whp, put something bigger in it. We run 8 1600's on the race cars and we're still almost out of fuel. I'm not sure that pump you have will flow enough either. Make sure you put a fuel pressure gauge on it so you can keep an eye on fuel pressure on the dyno, to make sure it's maintaining.</TD></TR></TABLE>
This guy doesn't know what he's talking about.. Dont listen to him
Old Jul 25, 2005 | 06:49 AM
DaveF's Avatar
a mechanical pump will be better off with a car on methanol.
Old Jul 25, 2005 | 11:03 AM
slowgti's Avatar
thanks for the tips, keep them coming if anyone has more. which mechanical pump would you recomend?
Old Jul 25, 2005 | 04:19 PM
lugnuts's Avatar
Default Re: (slowgti)
Hello. Are you on any of the vw boards(vwsport or poortex) ? whats your SN?
I dont think you want to go through the hassle of methanol for only 600 whp, the 16v motor will not have any detonation problems using C16 fuel.
If you want, shoot me an IM or E-Mail at Lugnuts9@msn.com with your complete setup, and goals, and I will help you out in any way I can.
Kevin
Old Jul 26, 2005 | 04:02 AM
slowgti's Avatar
i'm on the poortex and have tried to register for vwsport but won't ever let me. sent im
NY GsR
Aug 22, 2011 06:27 PM
dominidg123
Feb 4, 2010 09:57 AM
4LugR
Nov 15, 2008 02:26 PM
B18Sleeper
Oct 11, 2005 07:15 PM
zeroz
Apr 16, 2005 08:33 PM
