Ignition question????
Old Jul 23, 2005 | 01:07 AM
lucidvtec's Avatar
Default Ignition question????
i'm lookin to upgrade my ignition setup..i have the hondata s200...i have ngk 8mm wires...msd cap with external coil...should i get one of those amplifiers...or is it worth gettin a distributor less setup...which parts..i got money in my pocket...i don't wanna buy something i dont need ...or not have something i should...lemma know
Old Jul 23, 2005 | 04:19 AM
flip1199's Avatar
Default Re: Ignition question???? (lucidvtec)
what's wrong with your stock ignition? how much power u tryin to make?
Old Jul 23, 2005 | 05:35 AM
TheShodan's Avatar
Moderator
It's usually ok to run on stock ignition for about 300whp or below for that. The B-Series ignition system is very capable. However, from my experience w/ and w/o ignition amplification (ie. AEM CDI, MSD Digital 6 or SCI). I have found much improvement with the correct ignition system just to make sure that the fuel is burning effectively w/ the timing used. This is a great option especially if your goal is eventually to run over 350-400whp w/ good response, and not a lot of black smoke out of the back...
Old Jul 23, 2005 | 03:15 PM
lucidvtec's Avatar
anyone??????????
Old Jul 23, 2005 | 03:26 PM
flip1199's Avatar
Default Re: Ignition question???? (flip1199)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flip1199 &raquo;</TD></TR><TR><TD CLASS="quote">what's wrong with your stock ignition? how much power u tryin to make?</TD></TR></TABLE>
Old Jul 23, 2005 | 03:48 PM
lucidvtec's Avatar
i dunno...it's just kinda stock...my motor is gettin built..i just feel like i should change ..is what i got good enough for 400-500whp...msd cap with blaster ss coil...ngk 8mm wire's...ngk bcpr7es-11 plugs..????
Old Jul 23, 2005 | 03:50 PM
lucidvtec's Avatar
what about the block off kit's...that make it a coil system...which one is good..or is it not even worth it...
Old Jul 23, 2005 | 04:43 PM
flip1199's Avatar
Default Re: (lucidvtec)
people have taken good condition stock ignitions 400+whp. if it aint broke don't fix it. also u have hondata, i.e; still on the stock honda ecu, i.e.; COP is not doable.
hbhonda
Sep 4, 2005 10:35 AM
AutoEuphoria
Sep 25, 2004 07:50 PM
calib17a
Mar 22, 2004 07:13 AM
carblegal
Aug 28, 2002 11:00 PM
