another boost spike
Old Jul 25, 2005 | 10:19 AM
Midwest Auto Salon's Avatar
Default another boost spike
after days of research and trying everything i cant figure out why my car is spiking all the way to 17 psi when i have a 7 psi spring....any help would be appreciated...car ran fine until recently...
Old Jul 25, 2005 | 12:01 PM
11psiTurboSI's Avatar
Default Re: another boost spike (Midwest Auto Salon)
Are you running a DRAG manifold?
Old Jul 25, 2005 | 01:24 PM
Default Re: another boost spike (11psiTurboSI)
i am running a SS304 tubukar ramhorn style from Full Blown. Ran fine until recentyly, no cracks...
Old Jul 25, 2005 | 01:26 PM
boostedcivicsir's Avatar
Mr. Badwrench
where are you catching your boost signal for the waste gate?
if it isn't before the throttle plate, preferable right off of the compressor housing, start there. make sure your waste gate has a boost signal, if it does, hook a mighty vac to it and see if it holds vacuum, if it doesn't, your diaphragm is ripped.
Old Jul 25, 2005 | 01:30 PM
Default Re: another boost spike (boostedcivicsir)
i have a line going from w/g (top of tial) to the bottom of my mbc and the other one out the side of mbc to the intake manifold. i have no nipple on the compressor of the turbo. Ran fine and had it tuned at 300 whp and all of a sudden its fawked...
Old Jul 25, 2005 | 01:50 PM
Mr. Badwrench
take out the mbc, try to run it off of the compressor, check to see if the diaphragm is ripped or not.
Old Jul 25, 2005 | 01:53 PM
EJ1 wilcox's Avatar
What kind of MBC?
It could be sticking and causing a spike.
Does it hold steady at 17psi? Or, does it spike and then settle at a lower boost level?
Old Jul 25, 2005 | 04:13 PM
Default Re: another boost spike (EJ1 wilcox)
some gears it will hold sometime it will settle....i am running straight off w/g still hits 17 psi
Old Jul 26, 2005 | 09:59 AM
this sux, taking off w/g and testing spring today...
Old Jul 26, 2005 | 10:33 AM
SHystrdyGSRtdy's Avatar
keep us updated... check for ripped diaphram as stated above
Old Jul 26, 2005 | 12:54 PM
Default Re: another boost spike (SHystrdyGSRtdy)
checked the w/g no tears in the diaphram...checkin all lines now...thx
Old Jul 27, 2005 | 03:39 PM
thanks for the help for whoever replied...ended up being a stick mbc....changed out a new one and all good now.....looking for a e-tron one now....
Old Jul 27, 2005 | 04:35 PM
Mr. Badwrench
if you are looking at a good e-bc, may i suggest either the blitz dual sbc, which i have at 17 psi right now, or baller style with the sbc-id which is on out tt-350z.
Old Jul 27, 2005 | 05:07 PM
V8MeatHead's Avatar
From: Holley 4053, carb 406 stroker anal Luber, Fag
im not trying to be an ***, but why would you let your car boost that high and not taking your foot off of the gas pedal?
Old Jul 27, 2005 | 05:17 PM
whoneedzvtec's Avatar
Default Re: another boost spike (V8MeatHead)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by V8MeatHead &raquo;</TD></TR><TR><TD CLASS="quote">im not trying to be an ***, but why would you let your car boost that high and not taking your foot off of the gas pedal?</TD></TR></TABLE> he said it spiked whitch means that he was getting on it and it quickly jumped to 17 psi. it happens very quickly and i am sure he let out of it as soon as he figured out it spiked
Old Jul 27, 2005 | 05:30 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Midwest Auto Salon &raquo;</TD></TR><TR><TD CLASS="quote">some gears it will hold sometime it will settle....i am running straight off w/g still hits 17 psi</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Midwest Auto Salon &raquo;</TD></TR><TR><TD CLASS="quote">thanks for the help for whoever replied...ended up being a stick mbc....changed out a new one and all good now.....looking for a e-tron one now.... </TD></TR></TABLE>
how does that work?
Old Jul 27, 2005 | 05:48 PM
i think it also could of been the line i had going to the mbc and w/g...everything works good now. taking her back in for another tune....
1fastlude1
May 2, 2008 01:40 PM
Cowboy
Jun 16, 2003 02:12 PM
tegasaurus
May 28, 2003 01:48 AM
BoostedH23a1
Dec 3, 2002 07:04 PM
