b16a tranny question
Old Jul 24, 2005 | 10:52 PM
tony n.'s Avatar
Default b16a tranny question
sup
i dont know what forum to post this in....
but uh my boy has a b16 tranny with a messed up differential...and i have a ls tranny that works fine...i was wondering can i used the diff. from the ls and put it in the si tranny....
thx
Old Jul 24, 2005 | 11:07 PM
s2kdre's Avatar
Default Re: b16a tranny question (boosted2cam)
yea u can but the diff bearings are different,
Old Jul 25, 2005 | 02:37 PM
SuicideSlide's Avatar
Just make sure to swap the bearings over. And make sure the case matches up to the bearings.
Old Jul 25, 2005 | 02:41 PM
vaporboy12's Avatar
Default Re: b16a tranny question (TurbLu)
you got to change the final drive too i thought
Old Jul 25, 2005 | 04:42 PM
Default Re: b16a tranny question (vaporboy12)
nope, LS and B16a use the same final drive.
Old Jul 25, 2005 | 05:39 PM
SuperTeg95's Avatar
u must swap the ring gear for it to fit properly.
Old Jul 25, 2005 | 08:13 PM
nfn15037's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurbLu &raquo;</TD></TR><TR><TD CLASS="quote">nope, LS and B16a use the same final drive.</TD></TR></TABLE>
LS and 99-00 Si S4C tranny both use the same differential with the same bolt pattern. The Si tranny uses a 4.4 (66 tooth) ring gear while the LS uses a 4.266 ring gear.
Old Jul 26, 2005 | 10:05 PM
tony n.'s Avatar
Default Re: b16a tranny question (nfn15037)
cool, basically im askin do i have to buy any other parts? because i have a ls that is workin fine and the si tranny just needs a new diff. so can i just use everything from the ls? is it worth it for 250 for the si tranny with a messed up diff.?
extremeracer
Transmission & Drivetrain
Jan 3, 2009 08:54 PM
lilo_goki
Nov 13, 2007 05:46 PM
cherryB-16a
Mar 29, 2007 06:57 PM
vinuneuro
Oct 13, 2003 06:16 PM
AzntstyleZ
May 19, 2003 08:54 AM
