Oil return question
Old Jul 26, 2005 | 11:44 AM
TheIntegraGuy's Avatar
Default Oil return question
This question is pretty basic and simple.
Long story short, my car is throwing blue smoke out of the exhaust when I let go of the gas pedal. i was running a -4 feed line and then put a restrictor on it. It would still smoke. If I let the car idle and do nothing, it won't smoke. Then I thought it might have been the return line. I found a kink it in and changed out the return line. No more kink, but still throwing blue smoke. I can definitely smell oil burning.
I tried leaving it in Neutral and revving the motor up to 3k RPMs and held it there. Blue smoke would still pour out. There's no oil in the charge pipes, intercooler, or the exhaust side of the DP but only maybe because it has been burned off before it even reaches the downpipe.
If I disconnect the return line from the return flange on the pan, oil pours out but the flage is on top of the pan and I only put 3.5 quarts of oil in there.
I ran a wet compression test and got 200 accross the board.
At normal operating temperatures, with the motor still on, I removed the oil cap and saw no smoke. Also, no smoke out of the breather.
No signs of hesitation and car still runs fine. The only problem is that it smokes.
I don't want to jump conclusions, but here are some possibilties that I can think of..
- shot turbo seals
- cracked ringlands (but car still runs perfectly fine)
- turbo return flange on pan is in a bad position
- bad piston/piston rings
What could be wrong?
Old Jul 26, 2005 | 11:47 AM
beepy's Avatar
Default Re: Oil return question (TheIntegraGuy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">If I disconnect the return line from the return flange on the pan, oil pours out but the flage is on top of the pan and I only put 3.5 quarts of oil in there.
We have a winner.
If the oil drain is above the level of the oil the pressure will rise and you will blow oil past the seals. It is also possible that the seals blew already. It only takes a few miles of driving with a pressurized CHRA to blow the seals.
Old Jul 26, 2005 | 11:51 AM
dustin's Avatar
Default Re: Oil return question (beepy)
When the car is running the oil level is significantly lower, though.
Old Jul 26, 2005 | 11:52 AM
hmm.. Perhaps my seals were shot by the time I got to fix the oil feed line and the kinked return line..
Old Jul 26, 2005 | 11:57 AM
Dunc's Avatar
BCICAN
I'd be willing to guess that it is your rings.
Old Jul 26, 2005 | 12:04 PM
Default Re: Oil return question (Dunc)
Would u happen to know the symptoms of the rings?
Old Jul 26, 2005 | 12:10 PM
dustin's Avatar
Aren't you using a used turbo anyways?
I still think it's the turbo itself. But that's just me.
theo99gsr's Avatar
dont want to jack your thread but i thought you were supposed to mount the oil return line as high in the oil pan as possible.
Dunc's Avatar
BCICAN
My next reply was going to be to do a compression test and a leak down test. Those tests will determine if its the rings. (I just went through the same situation)
theo99gsr : That is correct.
Modified by Dunc at 4:29 PM 7/26/2005
Old Jul 26, 2005 | 12:16 PM
theo99gsr's Avatar
so whats up with this? If the oil drain is above the level of the oil the pressure will rise and you will blow oil past the seals.
wont mounting it as high as possible be above the level of the oil???
Old Jul 26, 2005 | 12:29 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dunc &raquo;</TD></TR><TR><TD CLASS="quote">My next reply was going to be to do a compression test and a leak down test. Those tests will determine if its the rings. (I just went through the same situation)
Modified by Dunc at 4:21 PM 7/26/2005</TD></TR></TABLE>
I did a wet test and it was 200 accross the board.. I don't know if doing it wet would effect the readings of the pistons/rings..
Old Jul 26, 2005 | 12:30 PM
Dunc's Avatar
BCICAN
ok compression is fine....now do a leakdown. My compression was fine too, but leak down showed bad rings.
Old Jul 26, 2005 | 12:36 PM
dustin's Avatar
What do you mean by wet? You poured oil in?
Old Jul 26, 2005 | 12:41 PM
Default Re: Oil return question (dustin)
I ddin't disconnect the ECU so it was feeding fuel.. (yes, stupid move)
Old Jul 26, 2005 | 12:43 PM
dustin's Avatar
That will mess up the numbers, yes.
You want the engine *HOT*, remove ecu fuse, hold throttle to the floor, and crank it.
By wet, I thought you meant you poured oil in each cylinder (about 1 cap full), to see if that helped the rings seal.
Old Jul 26, 2005 | 12:54 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dustin &raquo;</TD></TR><TR><TD CLASS="quote">That will mess up the numbers, yes.
By wet, I thought you meant you poured oil in each cylinder (about 1 cap full), to see if that helped the rings seal.</TD></TR></TABLE>
I THOUGHT about pouring oil, but I just wanted to try it first. I guess tonight I'll go home and try it again... I'm HOPING it's the turbo that's wrong. The min I started it up, it had smoked already when I first drove it, but then again with my luck, it could be something worse..
Old Jul 26, 2005 | 03:15 PM
Could the piston rings crack instantly after you start the car?
Old Jul 26, 2005 | 05:09 PM
y7turbo's Avatar
well since you said it smokes when you let go of the gas pedal and when you rev it at 3000rpm.. those sound like high vacuum situations to me.. check intake valve seals.. could be something else but you never know..
Old Jul 26, 2005 | 05:51 PM
KeyserSoze's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dunc &raquo;</TD></TR><TR><TD CLASS="quote">ok compression is fine....now do a leakdown. My compression was fine too, but leak down showed bad rings.</TD></TR></TABLE>
That is exactly what you need to do. My car was doing the same, I thought it was the turbo seals, which it was but after putting on a new turbo, the smoke persisted. I thought the oil in the dp and exhaust just needed to be burnt off, but the smoke didnt stop. The car ran fine with good comp and all, but the leakdown proved my rings were the problem. Do the leakdown and know for sure, it just makes sense.
Old Jul 27, 2005 | 09:46 AM
scartail's Avatar
bump... just subscribing...
Old Jul 28, 2005 | 08:28 AM
Default Re: (scartail)
Took off the turbo today for inspection again. I found oil on the exhaust side.. tons of it.. I'm going to switch out the turbo and if that doesn't work, then I'm sure it's the rings.. a leakdown will be in the works.
carlos8
Mar 20, 2012 06:20 AM
vangc6780
Apr 20, 2005 11:15 AM
drvfast
Jun 2, 2004 06:31 PM
_HANS
May 19, 2004 06:00 AM
playAho
Apr 16, 2004 04:57 PM
