Maximum rpm on stock B16 head?
Old 07-24-2005, 05:40 AM
mrx
mrx's Avatar
Default Maximum rpm on stock B16 head?
Hallo,
can someone tell me how much rpm is safe on a stock B16A Valvetrain/Head.
short period maximum (max. 5-10sec.)
long period maximum (> 30sec)
Thanks
Malte.
Old 07-24-2005, 05:46 AM
Boostage's Avatar
Default Re: Maximum rpm on stock B16 head? (mrx)
Stock redline is safe, 8k.
Old 07-24-2005, 07:24 AM
N_A_is_best's Avatar
Default Re: Maximum rpm on stock B16 head? (Boostage)
well i really wouldnt consider it safe forsay... but my friend has a gen 1 b16 with obd1 conversion type r cams and the skunk ecu and he takes it to 8500 all the time and still the stock valvetrain is good
Old 07-25-2005, 12:09 PM
tgreaves's Avatar
Or you can find ITR outer valve springs and get some Portflow inners($80) and youll be safe up to about 9K, this is only worthy if you cams make power up that high but can also help in an overrev situation..
Old 07-25-2005, 12:43 PM
tissimo's Avatar
We take my buddies boosted b16 first gen up to 8200-8400 all the time.. the rev limiter is at 8450.. everything is good on it.. cept the lma's need to be replaced..
Old 07-25-2005, 09:47 PM
hotimportcrx's Avatar
Default Re: (tissimo)
i go to 8500 all day...and sometimes 9 when i cant shift fast enough when boost hits....i had an incident when i was allmotor...i went to 9700 on a mis shift...thought my car was done...just put the spark plug back in and it was good....but anyways i wouldnt really be worried....take it to 8500 all day
Old 07-25-2005, 09:50 PM
Tchleung's Avatar
"short period maximum (max. 5-10sec.)
long period maximum (> 30sec)"
Why would you need to be that high in the revs for 5-10 seconds? elt alone greater then 30 seconds! You houdl only ever be abobe 8000RPM for a SPLTI second. If you're there for longer then that then you're going way too fast for the needle to be climbing that slow or something lol. I take my stocker to 8600. boosted.
Old 07-25-2005, 09:53 PM
Who is Mr Robot?
wantboost's Avatar
Default Re: (Tchleung)
took my stock na b16 to 9200 a few times, sucked. cams amke no power after 8500.
i plan on taking my 84.5mm fully built ls/vtec with fully built gsr head to 10k plus
2wheelhunter
08-15-2006 07:06 PM
TreeToTall
04-19-2006 06:33 PM
Waachback
34
03-29-2005 05:50 PM
Waachback
11
08-10-2004 02:41 AM
Waachback
06-25-2003 06:42 PM
Quick Reply: Maximum rpm on stock B16 head?
