tial bov not sounding right
official honda whore
well ive been listening to the tial 50mm bov i have and it just doesnt sound right, im running the stock spring in it and im idling at around 15-17 and at 21-22 when decelerating, is this the problem, im running .6 bar spring and it sounds nothin like the clips ive heard, sounds more like a rattle snake or something
right now im only running 8lbs, but plan to step it up to 1 bar as soon as i get my 3 bar wired in
brian
Modified by coptzer at 7:24 PM 7/25/2005
brian
Re: tial bov not sounding right (wantboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost »</TD></TR><TR><TD CLASS="quote">what sort of boost levels are you running.
and its not psi. vacuum is mm/hg </TD></TR></TABLE>
edited, thanks, jus typed it quick, and i also edited how much boost im running and planning on running, also does it matter if the bov is open at idle or not, im gonna run outside n check right now if it is or isnt
Who is Mr Robot?
Re: tial bov not sounding right (coptzer)
well, the spring in the bov is a 9 psi spring. you are running only 8psi. what you are hearing is pretty much compressor surge. and its normal for most piston type bov's to be open at idle
pm'd hopefully it will get taken care of with more boost or a smaller spring
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost »</TD></TR><TR><TD CLASS="quote">replied and problem solved i hope</TD></TR></TABLE>
yep just going to turn up the boost and deal with surge at low boost shifts
boosted_dc2
12-17-2003 09:32 PM
DIRep972
11-23-2001 05:17 PM
