post pics of your pipe/large hose from turbo to airfilter..need ideas
hey i need some ideas. its pretty tight in front of the rad to run a pipe. i have a 2.5: inlet on the turbo so i was thinking of running a 2.5" pipe but its got to twist alot so i dont know what to do so post pics of what you got going on
Mr. Badwrench
Re: post pics of your pipe/large hose from turbo to airfilter..need ideas (hamburgler)
covered here:
https://honda-tech.com/zerothread?id=1304175
but here is a pic of mine too: it is a 90degree with a k&n filter.
Ive seen a couple different setups:
I myself ran a 2.5 inch piece about 6 inch and then put the filter on it. This should put it right were the clutch line meets the bracket on the tranny. The bracket is held on with two bolts i took them both out and pushed it back and just used the rear hole to support the bracket this should allow enough room. Though it still is a tight fix.
Ive seen others even use types of flex pipe. There are also filters out there that are longer rather than fatter. You might be able to get one of these to fit right onto the turbo inlet.
Charlie Moua
Welding / Fabrication
15
01-08-2011 03:47 PM
Dampach1
08-28-2004 10:41 AM
BoostedVtecGsr
06-04-2004 12:26 AM
