What are most of you funning for total timeing?
What are most of you running for total timeing?
What are most of you running for total timing on about 2.1L on about 26psi? most people ive talk to around here are saying around 26. Srry for the noob ? im new to the tuning! Thanks Wade
Modified by boostedb18a at 11:33 PM 7/24/2005
Re: (boostedb18a)
26* timing on 26 lbs or boost???? when i tune cars i run 22* timing total on 8psi. on 26 psi u will want to run alot lower timing. i never tuned a car with that much boost but im gonna say around 5-7* for 26 psi
Re: What are most of you running for total timeing? (boostedb18a)
Just keep in mind every motor is different which in turn every motor is going to react different to various degrees of timing. Find MBT, pull a couple degrees off and be happy
Re: What are most of you running for total timeing? (0x64)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 0x64 »</TD></TR><TR><TD CLASS="quote">Just keep in mind every motor is different which in turn every motor is going to react different to various degrees of timing. Find MBT, pull a couple degrees off and be happy </TD></TR></TABLE>
...the only way!
...the only way!
Re: What are most of you running for total timeing? (adseguy)
Well the main reason i asked is b/c im running a MSEFI and i need to build a base timing map! Thanks Wade
I remember when I used to run 26 deg of timing, but only to found out my timing gun was busted. Bought a new timing gun to find out that my timing was out of phase by 10 deg retarded...lol
26* is insane... That's all I am going to say. Nobody here can give you a number because your engine is different from anyone elses.
