b18 or b20 for boost
Old Jul 24, 2005 | 04:59 PM
tobe1424's Avatar
Default b18 or b20 for boost
which would u recommend for boost....b20z or b18 non vtec(ls) ...i heard b20 have thing cylinder walls but they do have more displacement...help me out here for my lil ek
Old Jul 24, 2005 | 06:19 PM
non-VTEC's Avatar
Default Re: b18 or b20 for boost (tobe1424)
the B20 will make more all around power at the same boost level. as long as you keep the boost low (under 10PSI) and have it tuned safley the cylinder sleeves should be OK. but they have been known to crack.
the B18B will take more abuse and yes the sleeves are stronger but it will make a little less power......
Old Jul 24, 2005 | 08:10 PM
tobe1424's Avatar
Default Re: b18 or b20 for boost (non-VTEC)
my jdm freak friend of mine said that the only difference between the b20 and b18 is the stroke....not the bore....so he told me to boost the sh*t out of the b20 but then i do here from other ppl about the thing sleeves on the block and i comon sense tells me that a bigger displacement will hold more boost...but then everyone i know that boost their ls motors on stock internals never have no problems and create mad horsepower...
Old Jul 25, 2005 | 04:23 PM
noboostedEGo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tobe1424 &raquo;</TD></TR><TR><TD CLASS="quote">my jdm freak friend of mine said that the only difference between the b20 and b18 is the stroke....not the bore...</TD></TR></TABLE>
Your friend is wrong,
b18=81 mm bore
b20=84 mm bore
Old Jul 25, 2005 | 04:28 PM
b16sedan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tobe1424 &raquo;</TD></TR><TR><TD CLASS="quote">my jdm freak friend of mine said that the only difference between the b20 and b18 is the stroke....not the bore....so he told me to boost the sh*t out of the b20 but then i do here from other ppl about the thing sleeves on the block and i comon sense tells me that a bigger displacement will hold more boost...but then everyone i know that boost their ls motors on stock internals never have no problems and create mad horsepower...</TD></TR></TABLE>
Never ever listen to said friend again when it comes to cars, m'kay?
Old Jul 26, 2005 | 11:32 AM
tobe1424's Avatar
Default Re: b18 or b20 for boost (b16sedan)
lol ok thanks... so where do you think i can get a pretty cheap b18 ls around here? i want to build it and run all engine for a couple 1000 miles before boosting it..not to mention save up for the boost setup
andrearcher2003
Sep 22, 2011 01:36 PM
mysterysktr7
Apr 23, 2009 07:51 PM
3Rd GeAr PuLl
12
Feb 26, 2007 04:20 PM
Tofu94
Jan 20, 2005 06:48 AM
rtiadnoh
Apr 2, 2004 04:59 PM
