HELP: Turbo leaking oil
Old Aug 14, 2005 | 03:45 PM
TEG777's Avatar
Default HELP: Turbo leaking oil HAVE PICS
HAVE my turbo is leaking oil i have a picture attached and it is leaking on all 4 sides where i have an arrow, i think it is leaking right through the bolts, any one know why or what i can do
http://www.we-todd-did-racing....x.jpg
i can post more pics if neccesary
Old Aug 14, 2005 | 03:50 PM
s2kdre's Avatar
Default Re: HELP: Turbo leaking oil HAVE PICS (boostinteg777)
theres supposed to be 4 bolts there from the factory what happend to them, if u want u can weld them shut
Old Aug 14, 2005 | 03:53 PM
TEG777's Avatar
Default Re: HELP: Turbo leaking oil HAVE PICS (jdmhonda)
i have 3 out of 4 factory bolts, they were on i just took on off in the picture, is there supposed to be like teflon tape on them or something
Old Aug 14, 2005 | 04:02 PM
TEG777's Avatar
anyone else
Old Aug 14, 2005 | 04:38 PM
TEG777's Avatar
help
Modified by boostinteg777 at 6:49 PM 8/14/2005
Old Aug 14, 2005 | 05:49 PM
TEG777's Avatar
help
Old Aug 14, 2005 | 06:39 PM
EJ1 wilcox's Avatar
Those bolts hold the back plate onto the CHRA.
All 4 of them need to be there and torqued down properly in order to put pressure on the compressor seal. If you are missing a bolt or they are not torqued properly the compressor seal will not seal properly and it could cause it to leak.
I would try getting another bolt and tightening them all down. Then if it still leaks you might need a rebuild.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmhonda &raquo;</TD></TR><TR><TD CLASS="quote">if u want u can weld them shut</TD></TR></TABLE>
LoL... yeah, give that a try and see if it works.... Hahaha.
Old Aug 14, 2005 | 07:02 PM
TEG777's Avatar
Default Re: HELP: Turbo leaking oil HAVE PICS (EJ1 wilcox)
i do have the 4th bolt, i just took it off in the pic, do you need like teflon tape around it, and how many pounds do u torqe it down,
Old Aug 15, 2005 | 07:08 AM
TEG777's Avatar
Please help i need to get my car running
Old Aug 15, 2005 | 08:45 AM
EJ1 wilcox's Avatar
There's a link to the torque specs in this thread...
https://honda-tech.com/zerothread?id=1298985
Something like 8ft/lbs
civic-r11
Jul 26, 2010 03:24 PM
D15Bbigred
May 18, 2007 03:03 PM
elpiar
Jun 14, 2005 03:11 PM
99Sivic
Feb 1, 2005 09:22 AM
JoseCuervo
Sep 21, 2004 10:37 PM
