Wastegate Question
Old Aug 9, 2005 | 06:59 PM
$dollarbill$'s Avatar
Default Wastegate Question
I had a 3 inch exhaust made and the guy who made it put the dump tube back in the exhaust pipe but he drilled a half-inch hole for the gases from the wastegate to flow thru and just welded the dump tube over the hole. Its a Tial 38mm with a 10.5 spring. A half-inch hole isnt big enough for gases to flow through? My car was over boosting dramaticlly, and thats cause the hole wasnt big enough right?
Old Aug 9, 2005 | 09:48 PM
jfoster's Avatar
Default Re: Wastegate Question ($dollarbill$)
you are correct.
Old Aug 11, 2005 | 04:39 PM
Default Re: Wastegate Question (jfoster)
Thanks just wanted to check my knowledge, I tried to convince him to cut the hole the size of the pipe but he said it was plenty of room for the CFM's for that to flow, I said, its not an N/A car, turbo is different, its pushing the air out, not flow freely out.
SiRCiviC94
Jan 30, 2012 08:59 PM
sxysweed
Feb 6, 2011 09:52 AM
GSE980
Welding / Fabrication
May 14, 2009 10:34 AM
KevronsEG
Mar 8, 2004 04:38 PM
boondockgtr
Nov 13, 2003 10:00 AM
