PLX m300 install HELP
Old Aug 14, 2005 | 02:44 PM
ebp_dc2's Avatar
Default PLX m300 install HELP
I want my plx m300 to replace my existing narrowband o2 sensor. I am tuning with uberdata and would like to datalog at some point. My question is which wire do i replace with...the gray or the white wire? Also on the plx website it says something about resistors for the o2 heater...what do i do about that...is it necessary???? Thanks guys
SIDENOTE: Where is the best place to get power and ground from if im using it as a replacement for my narrowband?
Old Aug 14, 2005 | 05:02 PM
DutchEG6's Avatar
Default Re: PLX m300 install HELP (ebp_dc2)
I use Hondata and the PLX..
wideband sensor goes to the PLX then to the hondata and then to the ecu
Old Aug 14, 2005 | 05:58 PM
ebp_dc2's Avatar
Default Re: PLX m300 install HELP (DutchEG6)
up for uberdata
Old Aug 14, 2005 | 08:10 PM
LSTEG96's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DutchEG6 &raquo;</TD></TR><TR><TD CLASS="quote">I use Hondata and the PLX..
huh? you run a wideband wire from the blue box to the oem harness? or do u mean the signal??
Old Aug 14, 2005 | 08:19 PM
DC2-JRSC'd's Avatar
Default Re: PLX m300 install HELP (LSTEG96)
white one is for wideband ouput used when datalogging
gray one is for narrowband output
i get power from the ecu wires
and i dont have the resitor but i do get a code 1 every now and then.
go to uberdata forum, youll find a lot more info about common problems with the plx http://uberdata.pgmfi.org/forum/
Old Aug 14, 2005 | 09:08 PM
ebp_dc2's Avatar
ok thanks but if i want to use the wideband can i just hook that up to the ecu...does uberdata have wideband support
Old Aug 14, 2005 | 09:41 PM
DC2-JRSC'd's Avatar
Default Re: (ebp_dc2)
yes, you hook up the white wire to the 02 wire on the ecu. i forget what pin # it is. its in a post around here.
and yes uberdata has wideband suppoer. you need to check 2 boxes under misc, 02 heater and closed loop
Old Aug 15, 2005 | 08:27 AM
ebp_dc2's Avatar
Default Re: (DC2-JRSC'd)
hmmm my tuner jsut told me only to hook up the narrowband wire...that doesn't sound right?
Old Aug 15, 2005 | 08:59 AM
King Tut33's Avatar
I can't take this thread anymore. Get a switch, wire the output of the switch to the O2 sensor wire on your ECU. Then wire both the wideband and narrowband output of the PLX to the switch. Use the wideband when tuning and in open loop. Then flip the switch to the narrowband when running in closed loop once tuning is over.
Old Aug 15, 2005 | 09:28 AM
LSTEG96's Avatar
Default Re: (King Tut33)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by King Tut33 &raquo;</TD></TR><TR><TD CLASS="quote">I can't take this thread anymore. Get a switch, wire the output of the switch to the O2 sensor wire on your ECU. Then wire both the wideband and narrowband output of the PLX to the switch. Use the wideband when tuning and in open loop. Then flip the switch to the narrowband when running in closed loop once tuning is over.</TD></TR></TABLE>
awesome solution!
Old Aug 15, 2005 | 10:29 AM
ebp_dc2's Avatar
great solution...thanks!
Old Aug 15, 2005 | 12:41 PM
boosted k20's Avatar
run that switched wire to pin D14 on the ecu. and u dont need to install that resistor that the PLX comes with. in uberdata u have the option to disable the O2 sensor and heater so u wont throw a CEL. (once u finshed tuning the car, flip the switch and run the narrow band signal -grey wire, to Pin D14 so u dont throw a CEL for O2 sensor. even though u have disabled the O2 sensor in uberdata, it will still throw a cel if no signal is fed to pin D14.)
also uberdata has support for the PLX WB's. open up uberdata 1.7 and go to the datalogging menu. in there u can choose the PLX wideband to datalog. u will also need to install a datalogging cable in order to perform datalogging
Old Aug 15, 2005 | 08:45 PM
DC2-JRSC'd's Avatar
Default Re: (boosted k20)
you dont really need a switch either. what i did is installed a female end on the 02 wire from the ecu and a male on both the grey and white wire from the plx. i can switch wires whever i want and i dont need to mess with a switch. whatever works for you.
Old Aug 16, 2005 | 10:30 PM
D@nnY's Avatar
the resistor would be to trick the computer into thinking it still has a sensor its heating . (the stock one) you can just disable the heater if you have uberdata
Old Aug 22, 2005 | 06:26 PM
Turbo_Mike's Avatar
Default Re: (D@nnY)
I'm using the plx300 with no o2 and uberdata. Can i send the grey to the stock o2 sensor and use white on my a/f guage? I pop an o2 code everynow and again some i'm trying to get rid of it. Right now i have the gray wire going to my a/f guage
Old Mar 24, 2006 | 10:03 AM
the.hamburglar's Avatar
Default Re: (MIKE JONES)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MIKE JONES &raquo;</TD></TR><TR><TD CLASS="quote">I'm using the plx300 with no o2 and uberdata. Can i send the grey to the stock o2 sensor and use white on my a/f guage? I pop an o2 code everynow and again some i'm trying to get rid of it. Right now i have the gray wire going to my a/f guage</TD></TR></TABLE>
id like to know as well.
Old Mar 24, 2006 | 10:07 AM
Default Re: (the.hamburglar)
one more thing, can i just cut that wire that goes into the ecu pin d14 or should i splice into it? cutting it would make more sense to me, and i think ill do that switch idea.
Old Mar 24, 2006 | 10:14 AM
Kowalski's Avatar
How would you wire it if you had 2 O2 bungs?
Old Mar 24, 2006 | 11:07 AM
ryan89crx's Avatar
what about the noise filters? how necessary are they??
Old Mar 24, 2006 | 11:42 AM
Blackack26's Avatar
Default Re: (ryan89crx)
Ok, im about to install the M-300 and im running hondata. I'm assuming this way will also work with uber/crome ect. Just want to clarify things.
1) Replace stock 02 sensor with Bosch Wideband
2) Connect power and ground to wideband (use +12 and gnd signals close to ecu, if you can)
2) Buy a switch with 3 prongs, d14 (from ecu) goes to one prong as the input, the narrowband AND wideband wires from the sensor go to the other 2 prongs.
3) Have o2 sensor heater disabled all the time, in closed loop and open loop. So no need for resistors.
4) Tune the car with open loop selected and your neet little switch selected on wideband.
5) After you finish tuning the car and are about to burn your chip, select closed loop, and flick your switch to narrowband.
Is this correct?
Old Mar 24, 2006 | 12:01 PM
Default Re: (Blackack26)
thats what im going to do. i like that idea of the switch. good call! however i dont understand the closed loop and heater disable stuff...what does it all do
Old Mar 24, 2006 | 12:12 PM
Blackack26's Avatar
Open loop means it reads the fuel maps stored in the ecu ALL the time, no o2 sensor feedback.
Closed loop means under a high manifold vacuum, like when cruising, it reads the stock narrowband output from the o2 sensor and makes necessary changes to keep the A/F closest to 14.7 to 1. Saves gas basically.
And when the manifold pressure gets low, it kicks out of closed loop, and into open loop and starts reading the maps again.
Old Mar 24, 2006 | 12:55 PM
oh, so do i want to have closed loop checked all the time in uberdata?
Old Apr 2, 2006 | 03:35 PM
98civic94gsr's Avatar
So what exact pinouts do you wire the resistor into?
Where exactly do you hook up each end of the resistor to?
Its a jdm p72 ecu.
THanks,
98civic94gsr
Jeffro1265
Aug 17, 2010 12:05 PM
XX Boosted Si XX
Nov 21, 2005 07:48 PM
Evanmb44
Apr 6, 2005 12:11 PM
sol_1320
Apr 5, 2005 10:20 AM
turtle-eg
Mar 13, 2005 10:14 AM
