TD04 14G Water or Oil cooled?
I have a 14G TD04 turbo and the guy I bought it from was clearly running it w/ an oil feed. But If I can I'd like to avoid running the oil line and everything if I can just run coolant instead.
I know the 16G's off WRXs are coolant, but are the 14B/Gs?+
Thanks,
Nick
Thanks,
Nick
Re: TD04 14G Water or Oil cooled? (nota-eg)
The normal setup is either Oil or Oil/Coolant. If its an oil turbo... it needs it not just for cooling but for lubrication... don't skimp out here
Re: TD04 14G Water or Oil cooled? (splitime)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by splitime »</TD></TR><TR><TD CLASS="quote">The normal setup is either Oil or Oil/Coolant. If its an oil turbo... it needs it not just for cooling but for lubrication... don't skimp out here </TD></TR></TABLE>
Lub is a need in everyday life!
Re: TD04 14G Water or Oil cooled? (Siguy00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Siguy00 »</TD></TR><TR><TD CLASS="quote">Lub is a need in everyday life!</TD></TR></TABLE>
Word.
I already have an oil feed and return, I was just wondering if it was supposed to get oil or coolant. Don't want to fubar anything here.
So if it had 2 inlet it would more than likely be oil/coolant fed, but if its only got one line its more than likely oil only?
Thanks for the replys guys.
Word.
I just looked at the turbo it says 16. It's also got 4 inlets/outlets. 2 are blocked off. I'm gong to assume its oil/coolant fed, but is it okay to just use oil?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nota-eg »</TD></TR><TR><TD CLASS="quote">I just looked at the turbo it says 16. It's also got 4 inlets/outlets. 2 are blocked off. I'm gong to assume its oil/coolant fed, but is it okay to just use oil?</TD></TR></TABLE>
You must have a decent size turbo if its oil and coolant fed. And if you can use both i would.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Siguy00 »</TD></TR><TR><TD CLASS="quote">You must have a decent size turbo if its oil and coolant fed. And if you can use both i would. </TD></TR></TABLE>
Actually its an uber-small turbo. This weekend we just set it up to be oil cooled. Installation of the turbo kit was such a pain in the ***, with leaky injectors, blown o-rings, and broken bolts.
I'm glad to be back at work so I can get some R&R
SnIpErS-GsR
12-21-2006 09:16 PM
