turbo return placement
Old Aug 14, 2005 | 04:05 PM
TEG777's Avatar
Default turbo oil return placement
is my return high enough on the oil pan, it is a 97 acura integra, and how many quarts of oil should i put in the car, because when ever i put in the full 4 quarts like it says it is always coming out of the oil return, thanls
http://www.we-todd-did-racing....x.jpg
Old Aug 14, 2005 | 04:10 PM
SOHCD16y8's Avatar
Its up high enough, just fill to the stock 4 quarts. When the engine is running most of the oil will not be in the pan anyway.
Old Aug 14, 2005 | 04:14 PM
TEG777's Avatar
Default Re: (SOHCD16y8)
so it wont back into my turbo
Old Aug 14, 2005 | 04:15 PM
SOHCD16y8's Avatar
no it wont, as long as your line is nice and straight
Old Aug 17, 2005 | 09:02 PM
TEG777's Avatar
so if i fill it up with 4 quarts it wont back up into the turbo, is there anyway of knowing if it will back up into the turbo
Old Aug 17, 2005 | 09:16 PM
epic1si's Avatar
if the oil starts to back up into the turbo you'll be able to see the smoke coming from your exhaust.
Old Aug 17, 2005 | 09:32 PM
TEG777's Avatar
Default Re: (epic1si)
but when i have the car on the ground, and the return line disconected from the oil pan, when ever i pour all 4 quarts of oil in it starts to leak out from the fitting on the oil pan, when it all leaks out, it only shows halfway on the dipstick, is halfway enough oil to have in the car
Old Aug 18, 2005 | 06:30 AM
TEG777's Avatar
Default Re: (boostinteg777)
anyone know
Old Aug 18, 2005 | 07:12 AM
TEG777's Avatar
please help
Old Aug 18, 2005 | 08:08 AM
Blackack26's Avatar
SOHCD16y8 just gave you the answer in his post above
When the motors running, there will be alot less than 4 qrts in the pan. It might back up in the oil return a little when the car is off, but that doesnt really matter.
Old Aug 18, 2005 | 08:28 AM
HogWild's Avatar
Default Re: turbo oil return placement (boostinteg777)
Yea, as long as the fitting is up high enough you will be fine.
Old Aug 18, 2005 | 09:18 AM
Dunc's Avatar
BCICAN
Default Re: turbo oil return placement (HogWild)
Just put it as high as you can on the oil pan and call it a day. No need to worry over it.
Old Aug 18, 2005 | 09:49 AM
King Tut33's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostinteg777 &raquo;</TD></TR><TR><TD CLASS="quote">but when i have the car on the ground, and the return line disconected from the oil pan, when ever i pour all 4 quarts of oil in it starts to leak out from the fitting on the oil pan, when it all leaks out, it only shows halfway on the dipstick, is halfway enough oil to have in the car</TD></TR></TABLE>
Your trying to test your oil feed and return before hooking it up to the pan right and you are worried about not having enough oil in the engine to perform the test quickly. Well my solution is put a simple plug on the fitting on the pan so that you don't lose the oil before you start the car then start it make sure oil comes out the return. Shut off the car unplug the fitting on the oil pan and attach your return line. Your placement of the oil pan fitting is fine and once you are assured your feed line is working you are good to go.
Old Aug 18, 2005 | 04:08 PM
TEG777's Avatar
Default Re: (King Tut33)
so 4 quarts is ok
Old Aug 18, 2005 | 09:38 PM
SOHCD16y8's Avatar
YES!!!!!!!!!!!!!!
Dual Cam Killer
Dec 12, 2009 06:37 AM
thegatekeeper14
Aug 22, 2009 04:31 PM
jprelude92
Aug 30, 2008 07:12 AM
dart2.2
Jul 25, 2008 07:01 AM
Weston
Jan 26, 2003 01:37 AM
