Alcohol Injection ran safely
Old Aug 13, 2005 | 10:27 PM
DreamCatcher's Avatar
Default Alcohol Injection ran safely
Can I run Alcohol Injection instead of an IC. What are the negatives of doing this. I know the price and all, I just need to know the risks...I understand if the alcy fails what can happen.....
Old Aug 13, 2005 | 10:51 PM
OMG B16's Avatar
Run them both.
Old Aug 14, 2005 | 12:35 AM
Default Re: (Sick00SiCoupe)
What is wrong with just running alcohol injection? I dont want to run both, I do not want to run an IC at all.
Old Aug 14, 2005 | 01:26 AM
whoneedzvtec's Avatar
Default Re: Alcohol Injection ran safely (DreamCatcher)
alcohol injection is great go ahead and pick u up an aqua mist system and go to town on it man. its not unsafe as long as u set it up corectly. what kind of ems r u using. also. i recomend the aem ems. as long as u have those two things and a good tuner, u will be vary happy with it. i sold my aqua mist kit but i am about to buy another because i miss it. its great.
Old Aug 14, 2005 | 05:57 AM
Default Re: Alcohol Injection ran safely (dc2ls-t)
Im running turboedit, aem ems is too expensive for my posketbook, if i were to run a more standalone it would be from http://www.sdsefi.com.
Old Aug 14, 2005 | 06:35 AM
N20civicB18's Avatar
how come not many big HP guess run alky or water injection? I would think it would be a great thing to have, expessally if you have to do a quick highway blast
Old Aug 14, 2005 | 08:56 PM
unusual71's Avatar
if you "have to" nice
Old Aug 15, 2005 | 06:12 PM
BxCrx91's Avatar
you could definitly run just water injection without an intercooler even under higher boost levels. I've setup hondas running 10-12 psi with small turbos, which would generate more heat, and datalogged intake air temps anywhere from 100-120 degrees on days where outside temps where 80-95. And anyone who datalogged intake air temps with intercoolers know that 110-120 degrees with ambient temps in the 80's ad 90's is pretty damn good. The only disadvantage to water/alky injection is if you run out while boosting, damage can be done depending on how aggressive the tune is. With a intercooler you never have to worry if your bottle is filled or not. Just curious why don't you want to run a intercooler and water injection. If its for the stealth factor, you could always run a side mount and water injection.
integra686
Jan 16, 2005 03:41 PM
TypeR0186
Aug 4, 2004 10:19 AM
5thgen
Apr 11, 2002 08:22 PM
