hooking up MBC
Old Aug 12, 2005 | 11:42 AM
FrOsTwHiTeDC4's Avatar
Default hooking up MBC
Well I just recieved my Manual Boost Controller and was wondering if anyone can help me hook this thing up. Here are some pics:
If you need more pics just ask!
Thanks in advance
Albert
Old Aug 12, 2005 | 11:59 AM
JDMRice's Avatar
Default Re: hooking up MBC (jdmforlife)
http://www.geocities.com/chmwatson/FAQs/mbc.html
At the bottom theres a diagram, it might help.
Old Aug 12, 2005 | 12:18 PM
Default Re: hooking up MBC (SohcPower)
ok these are the 2 lines coming from the BOV and WG...both lines are the only hoses coming from either...so im still confused
Old Aug 12, 2005 | 01:32 PM
ttt
Old Aug 12, 2005 | 01:59 PM
ramennoodles's Avatar
should be a line from your turbo housing to the side of your wastegate. tee off that line, run it into the boost controller, the goes from boost controller to top of wastegate. thats if your have the kind that is a standard air pressure regulator that you can pick up from the hardware store. if you have the bleeder type( like the ones they sell on ebay) just tee off the line that goes from turbo to wastegate, run it into boost controller and leave other end of boost controller open. you do not need to route into your intake manifold
Old Aug 12, 2005 | 02:00 PM
Default Re: hooking up MBC (ramennoodles)
im not seeing any line from my turbo to my wastegate...i cant see any lines going to my wastegate..only the one coming off of it.
Old Aug 12, 2005 | 02:03 PM
in your picture you don't have any lines, you need to add them. that little piece of hose on your turbo needs to come off and add a line from there to the side off the wastegate. you will need to add fittings to your wastegate so you can attach the line to it.
Old Aug 12, 2005 | 02:04 PM
oh...ok
Old Aug 12, 2005 | 02:06 PM
ok, I see. your line on your wastegate goes to your intake manifold. take the end off from the intake manifold and plug it into your turbo compressor housing. then tee that off and add the boost controller to it. what style boost controller do you have?
Old Aug 12, 2005 | 02:07 PM
not sure ebay one you have AIM or MSN so i can contact you?
Old Aug 12, 2005 | 02:11 PM
msn: hamsarat@hotmail.com
k i added you
Project_EK
Apr 22, 2009 09:13 AM
hondamonkey
Nov 24, 2007 03:55 PM
GOIN V8 HUNTIN
Dec 10, 2006 10:51 AM
prelude_boi
Jun 12, 2003 08:03 PM
blackteg
May 22, 2002 11:51 AM
