Setting up Wideband Datalogging with Uberdata
Old Aug 13, 2005 | 09:36 AM
spike's Avatar
Default Setting up Wideband Datalogging with Uberdata
Did a quick search on the uberdata forum.. and didn't see any easy instructions..
Trying to setup a LM-1 wideband for use with Uberdata. Already have the ECU setup and chipped. Also have hte USB cable coming out of the ECU. Where do I tap into with the output signal from the LM-1? There's 3 wires on the output, which one goes where? Also wondering how to calibrate in Uberdata.
Thanks for any help.
Old Aug 13, 2005 | 09:39 AM
93turbo16's Avatar
it goes on the o2 sensor input to the ecu. White wire, around ecu pin D14.
PS. You didn't look to hard on the uberdata forum. There is a whole datalogging section. And I know your answer is in one of the stickies.
EkChuck
Engine Management and Tuning
Nov 24, 2012 03:24 PM
stocker2shocker91
Aug 25, 2007 04:23 PM
drintegra
Jan 10, 2007 01:15 PM
zexifiedlude
Sep 5, 2006 05:38 AM
antballs420
Apr 17, 2006 07:12 PM
