s300 and JDM Ecu
Old Aug 9, 2005 | 07:45 PM
Fatty_1775's Avatar
Default s300 and JDM Ecu
I heard that the s300 is not compatible with a jdm ecu? So does this mean I have to get another ecu?
Old Aug 9, 2005 | 07:54 PM
Fatty_1775's Avatar
Default Re: s300 and JDM Ecu (Autobot_Killer)
can i use and other b-series usdm ecu's?
Old Aug 9, 2005 | 08:00 PM
Redwidow's Avatar
Go to http://www.hondata.com tells you your options cut/dry...
Old Aug 9, 2005 | 08:01 PM
done's Avatar
yes you can get a usdm ecu and itll work..
p28 for example.
Old Aug 9, 2005 | 08:08 PM
Fatty_1775's Avatar
Default Re: s300 and JDM Ecu (Redwidow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redwidow &raquo;</TD></TR><TR><TD CLASS="quote">Go to http://www.hondata.com tells you your options cut/dry...</TD></TR></TABLE>
cut/dry? if i get a usdm ecu and just swap it, lets say a p28 swapped in instead of my jdm p30, will my car run the same? Until I get the s300?
Old Aug 10, 2005 | 08:30 AM
Redwidow's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Autobot_Killer &raquo;</TD></TR><TR><TD CLASS="quote">can i use and other b-series usdm ecu's?</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jordo@KAP &raquo;</TD></TR><TR><TD CLASS="quote">yes you can get a usdm ecu and itll work..
p28 for example.</TD></TR></TABLE> there's your answer,
I didn't see that question when i posted..
Old Aug 10, 2005 | 08:51 AM
Dee's Avatar
Dee
JDM P72's can be used because case is larger than a P30.
Old Aug 10, 2005 | 06:28 PM
Py7h0n's Avatar
Default Re: s300 and JDM Ecu (Dee)
You can use a JDM ECU without problems, you just need to be creative when mounting the S300.
Old Aug 10, 2005 | 07:32 PM
mamaboy's Avatar
Directly from the hondata web site
The s300 is made to fit in a full frame ECU case (US and most markets), so will not fit in a JDM ECU case.
Good Luck
Old Aug 10, 2005 | 11:08 PM
Redwidow's Avatar
Default Re: s300 and JDM Ecu (Py7h0n)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Py7h0n &raquo;</TD></TR><TR><TD CLASS="quote">You can use a JDM ECU without problems, you just need to be creative when mounting the S300.</TD></TR></TABLE>
What do you mean mounting the S300, they say the hardware is all internal with a usb port added...
I don't see it as the S200 little box that you can mount.
Save your self a headache and use what the maufactures suggest.
Old Aug 11, 2005 | 10:40 AM
Dee's Avatar
Dee
Default Re: s300 and JDM Ecu (mamaboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mamaboy &raquo;</TD></TR><TR><TD CLASS="quote">Directly from the hondata web site
Good Luck</TD></TR></TABLE>
That does not apply to the JDM P72 because it has a larger case and a knock sensor board. You only posted half of the answer on the Hondata page.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">[/i]Can I use the s300 in a JDM (square frame) ECU?
No. The s300 will only fit in the larger rectangular frame ECUs. [/i]ECUs with knock sensor boards are OK.</TD></TR></TABLE>
Old Aug 12, 2005 | 10:44 AM
tuoniz's Avatar
I might be stating the obvious here but the s300's main feature is that it is compatible with obd1 and 2 ecu's right.
Old Aug 12, 2005 | 03:35 PM
Spunkster's Avatar
Default Re: s300 and JDM Ecu (tuoniz)
The s300 will only work in the OBD1 ecus listed at http://www.hondata.com/ecus.html.
Old Aug 13, 2005 | 09:54 AM
JonnyCoupe's Avatar
Default Re: s300 and JDM Ecu (Spunkster)
From what i can see its mainly down to the knock board location, JDM is above the 28pin socket im sure moving that to be mounted outside the case and then trimming the middle support it would work ?
Old Aug 15, 2005 | 07:32 AM
Dee's Avatar
Dee
Default Re: s300 and JDM Ecu (JonnyCoupe)
My S300 just arrived (Thanks Ben@Importparts.com) so I'll let you guys know how my JDM P72 install goes.
Old Aug 22, 2005 | 04:24 AM
Dee's Avatar
Dee
Update - I am looking for a USDM ECU.
The support bridge for the knock sensor board is a major roadblock and even if you remove the bridge the daughterboard itself will be in the way.
If somebody wants to make some monEy I will trade (2) unchipped JDM P72's for a single P28/30/72.
Modified by Dee at 11:25 AM 8/22/2005
Old Aug 22, 2005 | 06:30 AM
tuoniz's Avatar
Got it thanks.
kobeRy_si
May 14, 2007 11:17 AM
Lauj87
Oct 16, 2005 10:27 AM
mprelude
Apr 26, 2005 05:07 AM
emark4
May 15, 2004 12:22 PM
hb_racer
13
May 13, 2004 08:54 AM
