tail wastegate install Q's.
Old Aug 11, 2005 | 11:46 AM
ultradx's Avatar
Default tail wastegate install Q's.
I have a 38 mm tail wastegate and my concern is that the port that bolts to the t-manifold has a ring on the wastegate that sticks out and and does not sit flush with the flange. Is this ring supposed to be like that or something is wrong?
Sorry for the rucky questions,but im new to the dark side, I also searched with no luck.
Old Aug 11, 2005 | 12:10 PM
ultradx's Avatar
Default Re: tail wastegate install Q's. (ULTRADX)
i need to know this,at this moment im installing my turbo kit.
Thank you.
Old Aug 11, 2005 | 12:15 PM
b18bturbo's Avatar
all you do is put the fire ring in the wg and tighten down. thats simple it will compress in when you tigheting it down
forgot to add that small side goes to the WG and the other side goes to manifold
Old Aug 11, 2005 | 12:17 PM
RacerXI's Avatar
On the base of the wastegate correct? It's like a small "ring" and sits just below the valve.
http://www.roadraceengineering...t.jpg
is it that?
Old Aug 11, 2005 | 12:24 PM
ultradx's Avatar
thanx for that advice.
simplegreenmachine
Apr 6, 2006 11:19 PM
godrifttoday
Nov 23, 2004 01:02 PM
redrocketgsr
Jul 23, 2004 08:58 PM
soulless1
Jul 19, 2003 07:22 AM
black2kgsr
Jun 6, 2003 07:32 PM
