The WEIRDNESS CONTINUES!!
Old Aug 11, 2005 | 10:20 AM
joshcivic00's Avatar
Default The WEIRDNESS CONTINUES!!
I went and replaced my battery which basically reset my ECU and now i have no CEL's but i am still having an idleing problem,it is really low 2-300 rpms,alot of times the needle is on zero!now i am clueless!A guy named jeff at Epik said that my o2 senors are out of spec(he didnt say they have failed)im hoping that since they are out of spec and not throwing a CEL that that is wa is causing the problem!!anybody have nay clues for this one??
P.S.my CAt is clogged(i have a CatCo on the way!)
Old Aug 11, 2005 | 10:30 AM
elpiar's Avatar
Default Re: The WEIRDNESS CONTINUES!! (joshcivic00)
How badly clogged is your cat?
Old Aug 11, 2005 | 11:43 AM
stackz's Avatar
at the jetties fishin'
Community Builder
Default Re: The WEIRDNESS CONTINUES!! (elpiar)
um, if you've got a replacement on the way, why not just pop yours off and use something to poke out all the paladium mesh inside it and see if that helps out...
also, get a cheap code reader and do the running tests and that will tell you if the o2's are out of whack or not.
TypeRod
Oct 17, 2013 09:18 AM
Crazyxc2448
Mar 25, 2010 03:56 PM
Two_K Si
Oct 13, 2004 08:32 PM
ajchen
Mar 26, 2003 08:23 AM
01itr518
Nov 6, 2001 07:21 AM
