Suggestions?
Old Aug 11, 2005 | 08:49 AM
2000turbosi's Avatar
Default Suggestions?
Im thinking about throwing a blox intake manifold/65mm tb/type r cams on to my setup...I just wanted to hear some suggestions from people...maybe see what somebody with a similar set up made on the dyno...my set up...b18c bottom end, arias piston (9:1) eagle rods, ls crank, stock sleeves....stock b16a head w/ adj. cam gears....t3/t4 turbo...inline pro exh. mani, turbosmart wastgate, precision 600hp intercooler, 2.5 inch charge pipes, hondata s200 with 550cc injectors...
my car with drag 3 kit (12lbs) made 279 whp 220lb ft torque....just trying to see if the upgrades listed above (intake mani, tb, type r cams) would be worth the money?....Im going to retune on 15lbs since i have a larger intercooler, and better wastegate that i just put on...
thanks for any help
Old Aug 11, 2005 | 09:30 AM
DaveF's Avatar
Default Re: Suggestions? (2000turbosi)
i would suggest at least throwing in a set of valve springs, so that you can take full advantage of the type-R cams.
Old Aug 12, 2005 | 06:02 AM
I answered my own question...i think the b16a head tb/intake manifold included...is pretty efficient up to 500-550 whp...so im going to stick with my stock head...thanks for the help though..plus ill prob. only make between 350-400whp...so its pointless for me to upgrade those parts discussed...
Angel4768
17
May 12, 2011 07:09 PM
vbspec
Jul 10, 2008 01:41 PM
Cprace1
Feb 11, 2006 11:06 PM
Cprace1
Feb 6, 2006 06:35 PM
juanb
Nov 18, 2005 06:11 AM
