Installing ARP head studs without ARP moly lube
Old Aug 13, 2005 | 06:52 AM
BlueShadow's Avatar
Default Installing ARP head studs without ARP moly lube
Hey guys,
I spent most of yesterday afternon assembling my motor. When I got to the part where I had to install the head onto the block I used my ARP stud kit and the ARP moly lube. I used the ARP moly lube on the bottom portion of the stud that goes into the block. However I didn't use any moly lube on the top threaded portion where the stud nut screws onto. I read that you can install the stud kit dry, or with no lube, you just have to change your torque settings. Do you guys think I'm fine with no ARP moly lube on the top threaded portion of the stud? or should I go back and redo it and use some ARP moly lube? the cam caps, and cams are already installed so I dont wanna have to go through all that again.
Let me know what you guys think
Old Aug 13, 2005 | 07:01 AM
non-VTEC's Avatar
Default Re: Installing ARP head studs without ARP moly lube (BlueShadow)
i always thought that you were NOT supposed to put any type of lube on the bottom threads. they go in dry.
also the spec sheet that comes with the stud kit should say what torque spec to use if you use engine oil instead of moly. i "think" its 80ft/lbs with oil. and 70ft/lbs with moly
Old Aug 13, 2005 | 07:34 PM
BlueShadow's Avatar
Default Re: Installing ARP head studs without ARP moly lube (non-VTEC)
I talked to Earl about it and he said that it doesn't hurt to have a little ARP moly lube on the bottom threads. I'm gonna check with ARP on Monday morning to see what they have to say about installing studs with no ARP lune on the top threads. I dont wanna redo my head, cause that means it'll set me back another day.
Old Aug 14, 2005 | 01:32 AM
whoneedzvtec's Avatar
ummm... i just let mine sit in a quart of un-used oil until i install them. never ever used any type of lube nor did i have any prblems at all
Old Aug 14, 2005 | 05:33 AM
musclefella's Avatar
Default Re: Installing ARP head studs without ARP moly lube (dc2ls-t)
I did Lube my bottom threads, that's what the lube is for. It's not there for nothing.
With the lube i torqued mine down in 3 steps to 81 ft/lbs as the manual stated.
Old Aug 14, 2005 | 06:51 AM
BlueShadow's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc2ls-t &raquo;</TD></TR><TR><TD CLASS="quote">ummm... i just let mine sit in a quart of un-used oil until i install them. never ever used any type of lube nor did i have any prblems at all</TD></TR></TABLE>
ummm...the ARP studs can be lubed with ARP moly lube or 30wt oil. So ummm...yeah.
Old Aug 14, 2005 | 04:11 PM
dr_latino999's Avatar
Default Re: Installing ARP head studs without ARP moly lube (musclefella)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by musclefella &raquo;</TD></TR><TR><TD CLASS="quote">I did Lube my bottom threads, that's what the lube is for. It's not there for nothing.
With the lube i torqued mine down in 3 steps to 81 ft/lbs as the manual stated.</TD></TR></TABLE> Ummm.... ARP says 60ft/lbs for there studs.
Old Aug 14, 2005 | 04:17 PM
SOHCD16y8's Avatar
I used 5w30 and 75ft/lbs on my friends motor and have had no probs after 1500-2000 miles
Old Aug 15, 2005 | 12:27 PM
Default Re: Installing ARP head studs without ARP moly lube (dr_latino999)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 &raquo;</TD></TR><TR><TD CLASS="quote"> Ummm.... ARP says 60ft/lbs for there studs.</TD></TR></TABLE>
sorry for my other statement, i've used loctite on the bottom threads.
I have an H22a and i think the ARP manual said 81 ft/lbs
jaron_cc
Apr 3, 2009 07:33 PM
1990_integra_DA9
May 19, 2008 04:57 PM
Flexin5
May 19, 2007 05:26 PM
W O T
Jun 11, 2006 09:48 PM
flip1199
Aug 2, 2005 12:28 PM
