GT40R vs PT71 GTQ........
Moderator
Re: GT40R vs PT71 GTQ........ (b00stedbyFastrax)
At those power levels that those turbos were designed for, honestly, spool up should not be a concern. Only power output. Those are NOT street/dragstrip type designs. Those are the serious almost track only condition turbos.
http://www.turbobygarrett.com/...2.htm
http://precisionturbo.net/turb...=3027
Check with a couple of the racers that have used the PT71-GTQ. I know Cort used it, but he is doing something different now from what I uderstand. The PT71 will allow you to get about 80 hp more in the bigger trim.
http://www.atpturbo.com/Mercha...e=GRT
Good luck,
Jason
Good luck,
Jason
Funny you posted this. I had a Pt71GTQ on order THEN the GT40R became available. I asked a couple of good tuners and engine builders, top turbo guys which one I should do. This is what i was told "Do you want to get down the track faster? Then GT40R! If you want to be a dyno queen then PT71GTQ!" I chose the GT40R but I dunno if the above statements are necessarily true BUT we shall find out REAL SOON!
Re: (Boostfed.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostfed.com »</TD></TR><TR><TD CLASS="quote">Funny you posted this. I had a Pt71GTQ on order THEN the GT40R became available. I asked a couple of good tuners and engine builders, top turbo guys which one I should do. This is what i was told "Do you want to get down the track faster? Then GT40R! If you want to be a dyno queen then PT71GTQ!" I chose the GT40R but I dunno if the above statements are necessarily true BUT we shall find out REAL SOON! </TD></TR></TABLE>
sooooo, the gt40r will produce a more useable powerband and make about the same power at per say 30psi @ 8500, whereas, the PT71 GTQ will produce more power when revving the **** out of the engine.
Re: (Boostfed.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostfed.com »</TD></TR><TR><TD CLASS="quote">Funny you posted this. I had a Pt71GTQ on order THEN the GT40R became available. I asked a couple of good tuners and engine builders, top turbo guys which one I should do. This is what i was told "Do you want to get down the track faster? Then GT40R! If you want to be a dyno queen then PT71GTQ!" I chose the GT40R but I dunno if the above statements are necessarily true BUT we shall find out REAL SOON! </TD></TR></TABLE>DYNO QUEEN?! bitch you almost made me laugh. I put the GT40R on and I could only run a 12 second pass. I put the PT71 back on and ran five 10.00s in a row and turned into Joe Simpson. J/K
No really....I think the GT40R will destroy the PT71 in spool time and reliability. But my presonal PT71 will destroy any GT40 out there. My 71 is a little different then the current PT71's.
There will be some new 71mm turbo's floating around soon from a couple different companies that will be tested soon. You guys will be the first to here about the test results.
Re: (uglyasscivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by uglyasscivic »</TD></TR><TR><TD CLASS="quote">DYNO QUEEN?! bitch you almost made me laugh. I put the GT40R on and I could only run a 12 second pass. I put the PT71 back on and ran five 10.00s in a row and turned into Joe Simpson. J/K
There will be some new 71mm turbo's floating around soon from a couple different companies that will be tested soon. You guys will be the first to here about the test results. </TD></TR></TABLE>
Doh should've got the PT71 for Dyno Queen status!!! I think the new bandwagon is the Gt42R
Re: (G"UNIT)
Cortney gave me a ride around the block when i was up in Utah in his hatch with a PT71gtq. Honestly that thing isnt laggy at all. Shes starts to spool mid 4000rpm and by a split second later its on the rev limiter with the front tires on fire. 480whp on pump gas (or something like that). It was super gnarly. I believe cort dynoed 803whp with that thing (search in the archives he posted it). Ran a 9.9 @ low ~150mph.
The same day we went out in another car with a gt40r, and i thought that was much lagger IMO. Still fast mind you...haha
liam
liam
Re: (liam821)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by liam821 »</TD></TR><TR><TD CLASS="quote">Cortney gave me a ride around the block when i was up in Utah in his hatch with a PT71gtq. Honestly that thing isnt laggy at all. Shes starts to spool mid 4000rpm and by a split second later its on the rev limiter with the front tires on fire. 480whp on pump gas (or something like that). It was super gnarly. I believe cort dynoed 803whp with that thing (search in the archives he posted it). Ran a 9.9 @ low ~150mph.
liam</TD></TR></TABLE>
Weird well one thing is the PT71GTQ that Cort has is only a .68 A/R turbine with housing with of course a GTQ turbine wheel then teh GT40R I have has a .95 A/R turbine housing and of course the GT40R turbine wheel which is bigger than a GTQ. I dunno we shall see if the GT40R is a good match on my motor, we should be dropping it in tomorrow or Tuesday!
Re: (Boostfed.com)
Weird well one thing is the PT71GTQ that Cort has is only a .68 A/R turbine with housing with of course a GTQ turbine wheel then teh GT40R I have has a .95 A/R turbine housing and of course the GT40R turbine wheel which is bigger than a GTQ. I dunno we shall see if the GT40R is a good match on my motor, we should be dropping it in tomorrow or Tuesday! </TD></TR></TABLE>
Correct cort had the .68ar exhaust. It really did spool quick!!! You gotta report back and let us all know how the gt40r with the .95ar spools - thats a big turbo!!!
liam
liam
Moderator
Re: (b00stedbyFastrax)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b00stedbyFastrax »</TD></TR><TR><TD CLASS="quote">what is the availability of the Gt40R?</TD></TR></TABLE>
Usually I can get those in about a week or so, usually special order. Most people don't keep it in stock.
I PM'ed you, I can get ahold of 3 right now
Re: (Boostfed.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostfed.com »</TD></TR><TR><TD CLASS="quote">Weird well one thing is the PT71GTQ that Cort has is only a .68 A/R turbine with housing with of course a GTQ turbine wheel then teh GT40R I have has a .95 A/R turbine housing and of course the GT40R turbine wheel which is bigger than a GTQ. I dunno we shall see if the GT40R is a good match on my motor, we should be dropping it in tomorrow or Tuesday! </TD></TR></TABLE>
The GTQ turbine is a 79mm inducer/68mm exducer.
On the GT40R, I have found various specifications on the trim. The 73 trim GT40R is a 77mm inducer/65.8mm exducer. The 78 trim GT40 turbine is 77mm inducer/68mm exducer. There might also be an 84-trim GT40R, which would be 77 inducer/70.6 exducer.
The GTQ is larger then all but the 84-trim, which I'm not 100% sure is even avaliable.
Cort, I'm interested in hearing about these 71mm turbochargers coming out. I've been talking with a company about a turbo that meets exactly SFWD rule limits and it is targeted for high pressure ratios with reasonable spool.
