Pocket Programmer II with Romulator
Old Aug 12, 2005 | 07:50 PM
spike's Avatar
Default Pocket Programmer II with Romulator
Can't get my pocket programmer to write to the Romulator.. what Chip and settings are you guys using to burn to the romulator? Using The Pocket Programmer II with windows software. Can burn a AT29C256 without a problem..
Thanks.
Old Aug 12, 2005 | 07:56 PM
TurboTegB18c's Avatar
Default Re: Pocket Programmer II with Romulator (spike)
Are u using this for hondata?
I'm running the romulator straight off the computer, without the programmer.
Old Aug 12, 2005 | 08:00 PM
Race Egr's Avatar
Default Re: Pocket Programmer II with Romulator (TurboTegB18c)
the pocket programmer dosent write to the romulator. You do upload ur map to the romulator. then tune in real time with it. Then use the pocket programer and burn the chip with it. Their is no connection at all betwee the pp and romulator. Maybe you shouldnt be messing with it yourself if your that confused
Old Aug 13, 2005 | 06:44 AM
spike's Avatar
Default Re: Pocket Programmer II with Romulator (NAPIER)
if that is the case then how are people using the romulator with Uberdata? I was under the impression that it is just a eprom that you do not need to swap out evertyime..
I am not using Hondata.
crxb16a90
Engine Management and Tuning
Aug 10, 2009 08:13 AM
civel
Jan 24, 2006 08:58 AM
youngvedder
Jul 27, 2005 11:36 AM
b16 matt
Feb 23, 2004 06:43 PM
2K_TEG
Jul 23, 2003 06:00 PM
