Correct me if I am wrong.........
Old Aug 10, 2005 | 08:25 PM
txturbogs's Avatar
Default Correct me if I am wrong.........
I am about to place an order for some spark plugs...R5672A-8. I am boosting 10psi on a built LS block with a GSR ported hear. The turbo is a 60-1. I am running BKR7E-11 right now. Also, what gap should I use for the BKR7's and the R567a-8's? I read that the correct gap is .35, for both. Thanks for any advice.
Old Aug 10, 2005 | 08:31 PM
KeyserSoze's Avatar
Default Re: Correct me if I am wrong......... (txturbogs)
I have mine gapped at .28 (this is what AEM recommends for up to 20 psi of boost). I'm sure you will get answers that vary slightly. GL.
Old Aug 10, 2005 | 08:39 PM
EnzoSpeed's Avatar
Default Re: Correct me if I am wrong......... (KeyserSoze)
I don't have an answer for you, but then again, I didn't know what kind of thread I'd be reading becuase you picked such a stupid title.
Old Aug 10, 2005 | 08:54 PM
mike93eh
Guest
Posts: n/a
Old Aug 11, 2005 | 06:13 AM
ginoboy1978's Avatar
NGK says for every 50whp gain, should lower gap by .004 from stock gap.
And, for every 75-100whp gain, should go one step colder from stock level.
For example, my car is as follows:
Stock: 105whp
Now: 180 whp
Gap(stock): 0.044
Gap(now): 0.036
Level (stock): 5
Level (now): 6 (NGK BKR6E)
Car runs perfect.
DAN
Old Aug 11, 2005 | 02:56 PM
EnzoSpeed's Avatar
Default Re: Correct me if I am wrong......... (ginoboy1978)
^^That's good info. And your avatar is... confusing
Old Aug 11, 2005 | 03:26 PM
Default Re: Correct me if I am wrong......... (EnzoSpeed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EnzoSpeed &raquo;</TD></TR><TR><TD CLASS="quote">^^That's good info. And your avatar is... confusing </TD></TR></TABLE>
Thanks man.
Regarding the avatar......its a woman's hand on a computer mouse.
DAN
Old Aug 11, 2005 | 03:32 PM
ramennoodles's Avatar
just to let you know, you don't need that last number. on the bkr7e-11, the -11 is the size the plug comes pre-gapped
Old Aug 11, 2005 | 04:26 PM
jdmturbosol's Avatar
Default Re: Correct me if I am wrong......... (ramennoodles)
i run the 9's for 600whp
they are gapped at .014
for street driving on pump gas
I run bkr7e's at .020 on the street
accord99power
Oct 21, 2008 08:06 PM
s2kkid
Jan 8, 2006 06:52 PM
TEG777
Oct 3, 2005 04:43 PM
integranator
Apr 1, 2003 02:08 PM
VTC_CiViC
Jul 22, 2002 01:16 PM
