IS this CO2 Setup possible?
Old Aug 10, 2005 | 11:34 AM
Paperweight's Avatar
Default IS this CO2 Setup possible?
I got a bunch of 12 and 20 oz CO2 tanks from paintballing. I was wondering if I could use those bottle for an Ntercooler type setup? I was watching the first fast and furious and saw Vin diesel's rx7 had a bunch of small NOS bottles, I want the same thing. I want to set up 3 small bottles but have them pressurize into one line.Does this kind of setup have a name? has anybody heard of something like this? is it possible? let me know
Old Aug 10, 2005 | 01:49 PM
Jizzmaster Zero's Avatar
(banned)
Default Re: IS this CO2 Setup possible? (Paperweight)
You are retarded. Hang yourself.
Old Aug 10, 2005 | 02:32 PM
ComputerJLT's Avatar
no no no
inject the co2 into your intake; it'll SUPERCOOL your air!!!
its worth like 18whp per liter of displacement
Old Aug 10, 2005 | 03:08 PM
SOHCD16y8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Paperweight &raquo;</TD></TR><TR><TD CLASS="quote">? I was watching the first fast and furious </TD></TR></TABLE>
Theres your problem
Old Aug 10, 2005 | 03:42 PM
bloodypiranha's Avatar
Default Re: IS this CO2 Setup possible? (SOHCD16y8)
Ya i figured i would get ripped on. I just want to make a Ntercooler for cheap...
Old Aug 10, 2005 | 04:15 PM
Finest's Avatar
Default Re: IS this CO2 Setup possible? (bloodypiranha)
So, how many other accounts do you have on here?
But to answer your question, you just need a simple distribution block that you can plug in however many ports (bottles) you'll need. Then have it discharged out from a bigger port to your setup. Kind of like the GE vacuum manifold, but in reverse.
BTW, don't mention Fast and the Furious again. Or even mention using anything from the movie.
Old Aug 10, 2005 | 05:02 PM
DreamCatcher's Avatar
Default Re: IS this CO2 Setup possible? (Finest)
wouldnt water injection be cheaper?? What are actual effects of running CO2?
Old Aug 10, 2005 | 05:06 PM
nota-eg's Avatar
Default Re: IS this CO2 Setup possible? (ComputerJLT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ComputerJLT &raquo;</TD></TR><TR><TD CLASS="quote">no no no
its worth like 18whp per liter of displacement</TD></TR></TABLE>
NO! CO2 makes your motor cutoff. I was bored one day so I ran a line from inside the cab of my car to my intake, turned on the car, cracked the bottle and my car studdered and then died.
Yes, I am retarded.
You could always get 3 of the gun pieces that the bottles screw into, run them into one line, and then have that line run to a propane grill coil that you mount in front of your IC.
r1ch1e
Nov 17, 2006 10:51 AM
le0ftw
Nov 15, 2006 09:39 AM
mustninty
May 15, 2004 03:03 PM
eddiecut
Mar 20, 2004 06:10 PM
nuro
Nov 14, 2003 06:48 PM
