map code and waste gate not oping help!!!
Old Aug 10, 2005 | 08:28 PM
craio's Avatar
Default map code and waste gate not oping help!!!
well first my set up is
super 60
450cc
open dp for now
tial wastegate hooked up to compressor
and the safcII
when i first started it. it ran like crap so i tryed messing with the settings nothing its set to -47 at idal and still i have a bad idal. so i drive try to boost it bogs realy bad around 3200-4200. so once i finaly get it to boost it just goes to 10psi and keeps going with a 6lb spring.... and i got the map code so i bring it back play with same thing. except now its throwing the code even at idal. i check the wiring on safc for a bad conection by the map and it looks fine. what could be causing the boosting and the map problems
Old Aug 12, 2005 | 08:21 PM
jdmteggi's Avatar
Default Re: map code and waste gate not oping help!!! (craio)
bump
its all most iposible for me to tighten the bottom bolt on the waste gate could that cause this that the valve is not seated right
Old Aug 13, 2005 | 07:19 AM
craio's Avatar
Default Re: map code and waste gate not oping help!!! (jdmteggi)
Old Aug 13, 2005 | 08:17 AM
craio's Avatar
edit the boost gauge only read like 12-15 of vaccume at idal
teg_95
Apr 28, 2009 07:19 PM
eggie75
Apr 7, 2008 01:40 PM
platinum00
Jul 25, 2003 09:16 AM
platinum00
Jul 24, 2003 08:02 AM
