NEED HELP,now CEL code 45!!
Old Aug 11, 2005 | 06:58 AM
joshcivic00's Avatar
Default NEED HELP,now CEL code 45!!
code 45(4 long,5 short)which is a malfunction in the fuel monitoring system because it is too lean or too rich!!does this basically mean that i am either running to lean or too rich for what the engine specifies???could this code be caused by bad 02's and clogged CAT???can anybody help
Old Aug 11, 2005 | 07:51 AM
blaze the chemi's Avatar
Default Re: NEED HELP,now CEL code 45!! (joshcivic00)
Go to autozone or pepboys and ask to borrow the OBD2 Scan tool. It'll tell you the actual "P" number to tell you if your either rich or lean. Then look at the troubleshoot in the Helms. If you don't have a Helms, then order it or borrow a friends. Good luck.
masijdm
Feb 26, 2009 05:35 AM
94typeR
Mar 31, 2007 03:57 PM
96CivicBoostCoupe
Aug 5, 2005 10:31 PM
boosted k20
Sep 11, 2004 07:32 PM
