Installing ARP Head Studs. Write Up? How To? D16A6
Old Aug 12, 2005 | 12:02 PM
W O T's Avatar
Default Installing ARP Head Studs. Write Up? How To? D16A6
Hey guys
Just looking for some info on how to install my ARP head studs into my D16a6
Just wonderring if theres any special info and just generally how to do it
I know with my motor ones bolt is longer and Ive guess Ive got to find which hole that is
Hope someone has some info
Thanks
Old Aug 12, 2005 | 12:38 PM
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Default Re: Installing ARP Head Studs. Write Up? How To? D16A6 (W O T)
Get a Haynes or Helms manual for the general install.
Specific to ARP headstuds, it's 1.) hand-tight on the block with allen wrench, then 2.) 20 ft./lbs tq, 3.) 40 ft./lbs. tq, 4.) 65 ft./lbs. tq, then again for good measure.
Use the ARP lube, not oil. Don't go over 70 ft./lbs, because ARP recommends 52ft/lbs.!
Copper spray for the HG too
Old Aug 12, 2005 | 02:12 PM
W O T's Avatar
Default Re: Installing ARP Head Studs. Write Up? How To? D16A6 (boostincoupe)
Im assuming I use the double nut teqnique to get them on?
From inside to outside, outside to inside, criss cross
matter?
copper spray available at....?
Old Aug 12, 2005 | 02:19 PM
gtcali's Avatar
I double nutted my on.
Get the torque sequence for you head.
Old Jun 11, 2006 | 08:17 PM
beef-cake's Avatar
What's this copper spray for the headgasket stuff?
Old Jun 11, 2006 | 08:45 PM
twkdCD595's Avatar
Default Re: Installing ARP Head Studs. Write Up? How To? D16A6 (beef-cake)
I guess the ones for the d16 must be different than the ones I am going to use in my f22.
Their instructions say to torque the ones I have to 80 ft. lbs. with arp moly assembly lube.
Old Jun 11, 2006 | 09:40 PM
Si Shane's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by W O T &raquo;</TD></TR><TR><TD CLASS="quote">Im assuming I use the double nut teqnique to get them on?
matter?
copper spray available at....?</TD></TR></TABLE>
My headstuds had an allen recess on the top.
Old Jun 11, 2006 | 09:48 PM
Dartanian's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beef-cake &raquo;</TD></TR><TR><TD CLASS="quote">What's this copper spray for the headgasket stuff?</TD></TR></TABLE>
I think it is this stuff: http://www.permatex.com/produc...t.htm
I am subscribed for a good answer to this myself and a place to buy it since I need to get my head resurfaced and with a new headgasket running $60, I would rather see if I can use a copper spray.
alx_90ef
Mar 10, 2010 05:52 PM
95_red_dc
Aug 31, 2008 09:28 AM
Flexin5
May 19, 2007 05:26 PM
boomersz
Feb 24, 2007 09:56 AM
ivt-t
Feb 8, 2007 09:15 PM
