Which headgasket?
Old Aug 10, 2005 | 07:22 AM
RedR's Avatar
Default Which headgasket?
I have a type R with 11:1 compression, i plan to run stock internals for a while, what size hg should i get? I want it to be reliable and if possible 300 whp.
3mm is a lot?
Waiting on some feedback, thanks
Old Aug 10, 2005 | 08:26 AM
Redwidow's Avatar
Default Re: Which headgasket? (RedR)
are you going turbo?
Old Aug 10, 2005 | 08:49 AM
King Tut33's Avatar
Default Re: Which headgasket? (Redwidow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redwidow &raquo;</TD></TR><TR><TD CLASS="quote">are you going turbo? </TD></TR></TABLE>
Is this the forced induction forum? Just go with an OEM headgasket. You can still turbo an 11:1 compression car you just can't run as much timing.
Old Aug 10, 2005 | 04:16 PM
RedR's Avatar
Default Re: Which headgasket? (King Tut33)
of course im going turbo, and no, running stock compression is out of the question i wanna squeeze some power out of it.
Old Aug 10, 2005 | 04:59 PM
King Tut33's Avatar
If stock compression is out of the question then get some lower compression pistons and still use an OEM head gasket. Using double thick gaskets is not the way to lower compression.
Old Aug 10, 2005 | 05:05 PM
cuin9sec
Guest
Posts: n/a
cant go wrong with OEM. ive had nothing but problems out of the past 4 cometics ive used...lol!
Old Aug 10, 2005 | 11:13 PM
Redwidow's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by King Tut33 &raquo;</TD></TR><TR><TD CLASS="quote">
Is this the forced induction forum? Just go with an OEM headgasket. You can still turbo an 11:1 compression car you just can't run as much timing.</TD></TR></TABLE>
Do people post in the wrong forum like daily? duuh, just asking..
And plus if your asking questions like this your gonna be playing with fire on your setup...good luck
suno
23
Nov 28, 2008 02:20 AM
icebergli
Jul 20, 2005 10:28 AM
LSEGHATCH
Oct 6, 2004 07:44 PM
Doug684
Dec 30, 2003 09:59 AM
MUGENTYPER
Feb 6, 2002 06:31 AM
