Idle Problem
Old Sep 19, 2005 | 08:26 AM
RotiEatter's Avatar
Ditto
Default Idle Problem
Setup consists of 00 Civic EX, stock D16Y8, Spoolin Performance mani, DP, Garrett T3/T04E. On intial start-up the car was idling fine, it was on the stock ECU and injectors, just for startup. Everything was fine, then the idle jumped to 3000 rpm. I shut the car off and wired in the OBD1 clips and 440cc injectors, and Uberdata. Started it up again and same high idle. At 2500-3000 rpm gauge is reading 20hg. When i make the revs drop to 1000, gauge reads 10hg. So I am thinking a vacuum leak. Replace vacuum lines and vacuum tee. Still nothing. Help with any ideas please. BTW search isnt working
Old Sep 19, 2005 | 08:45 AM
RotiEatter's Avatar
Ditto
Drove it around the neighborhood and now it is surging from 2000-2500.
Old Sep 19, 2005 | 09:52 AM
RotiEatter's Avatar
Ditto
Default Re: (RotiEatter)
Started it up with a stock P28, car idled fine for a minute. I didnt drive it. Is it possible that the car is idling proper with the sotck ecu b/c of the 440 injectors kinda bogging?
Im confused
Old Sep 19, 2005 | 10:16 AM
RotiEatter's Avatar
Ditto
Does the D16Y8 have a FITV on the bottom of the TB?
Old Sep 19, 2005 | 12:02 PM
RotiEatter's Avatar
Ditto
i dont see one. Please help
Old Sep 19, 2005 | 01:02 PM
ginoboy1978's Avatar
Is your ECU tuned, or you running on a basemap?
DAN
Old Sep 19, 2005 | 01:24 PM
RotiEatter's Avatar
Ditto
Default Re: (ginoboy1978)
basemap
zach1288
Jun 12, 2010 04:32 PM
JHP
Jan 29, 2009 09:18 AM
99GreenEX
Nov 29, 2007 07:52 PM
JunY
15
Jun 30, 2005 08:55 PM
JBBNJ609
Jul 15, 2003 11:49 PM
