13.8 d15b7
Old Sep 20, 2005 | 11:02 AM
bennyhonda7's Avatar
Default 13.8 d15b7
d15b7 made 215 hps 182 lb ft... ran 13.8 1/4 with a 2.4 60ft...
d16a6 si cam
d16y8 mani
hf mani with 14b turbo
uberdata
dx tranny (sucks)
no slicks 13 stock steelies
450 dsms
tanabe g 3inch exhaust with 3inch dp
Old Sep 20, 2005 | 11:07 AM
1boostedcivic's Avatar
Default Re: 13.8 d15b7 (bennyhonda7)
what chassis?
Old Sep 20, 2005 | 11:09 AM
95 coupe stripped dx
Old Sep 20, 2005 | 11:33 AM
nonvtecD's Avatar
represent
Old Sep 20, 2005 | 12:19 PM
RotiEatter's Avatar
Ditto
Nice job man...
Old Sep 20, 2005 | 12:21 PM
HiProfile's Avatar
I was thinkin...kinda bad times for boost ... then I read "no slicks 13 stock steelies" ahaha, thats great. It almost makes you want to laugh at the guy putting 4-5k into his b16 and barely doing low 14's. BTW how much psi?
adseguy's Avatar
Default Re: (RotiEatter)
mph? and weight? impressive though for a 2.4 60ft.
Old Sep 20, 2005 | 12:30 PM
Calvinator's Avatar
Default Re: (adseguy)
how much boost did it take you to get to 215whp on a 14b? thats pretty impressive. I know that my old 14b setup was nowhere near that. haha.
Old Sep 20, 2005 | 04:47 PM
Dr. D-Series's Avatar
That car can run way faster than that on steelies.
I did 13.7 in a 97 ex shell with a b7.
Old Sep 21, 2005 | 07:03 AM
Default Re: (Dr. D-Series)
that was on 9psi...14b...the dyno on 215 was made with 8psi...before tuned (myself( it made 182 with conservative timing and fuel...then after tune 215 so pretty good...i think next im thinking more agressive cam....and something to the bottom end but dont know what in the process of building an a6....so im thinking around 270ish with that on 12-13psi? car weighed in at 2235... a6 build consists of new bearing. crower rods, turbo cam, same bore, ferrea valve train oversized valves,and pulleys, etc..etc.... its about 2 months from complete
Old Sep 21, 2005 | 07:40 AM
nonvtecD's Avatar
215 hp, b7, 8 psi on a 14b.... Something doesn't add up. Say the B7 makes 95 at the wheels NA. You're saying you made 110 hp on 8 psi with a 14b. I can't see that.
Old Sep 21, 2005 | 09:14 AM
Default Re: (nonvtecD)
d15b7 has d16a6 si cam, d16y8 manifold...those things really help power out top end especially past 5500 rpms and the si cam still pumps power at 7500 rpm so yeah it is possible....just like a z6 with 112 to the wheels stock puts 220 to the wheels on 8 psi with a good tune....also the d16a6 and b7 are very underated engines...mine before boost could keep with and pass z6 when i had my si tranny....just the rods suck.
Old Sep 21, 2005 | 10:05 AM
BoOstedEM1's Avatar
Default Re: (bennyhonda7)
same time as stock 05 gt mustang. Good job man..
Old Sep 21, 2005 | 10:23 AM
Default Re: (BoOstedEM1)
yeah thats why im building the a6 to break into the high 12 or low 13's...
Old Sep 21, 2005 | 10:54 AM
93preludes's Avatar
everytime i see this stuff it makes me regret buying a bseries for my crx, big d
Old Sep 21, 2005 | 01:11 PM
nonvtecD's Avatar
you have a dyno sheet or timeslip? I'm just saying that is a lot of power for a tiny turbo on low boost. My T3 sure as heck isn't making 215 whp on 8 psi.
Old Sep 21, 2005 | 01:35 PM
AbitAvenger's Avatar
seems fishy, z6 with a 14b at 8 psi would make around 200 to the wheels correct(good tune)? AND THEY HAVE MAD VTAKK!! so wtf?
Old Sep 21, 2005 | 03:34 PM
Default Re: (AbitAvenger)
sorry bro but i have to call bs. theres no way u can make that much power on just 8 psi with that turbo. unless your just on some lean *** fuel map with lots of timing. but i dont believe that bottom end would last for more than a few days like that much less a quarter mile and dyno pulls.
Old Sep 21, 2005 | 04:14 PM
SOHC_MShue's Avatar
14b+ d15b7 + 8psi does not = 215whp. Even with that cam and intake manifold. Heck my z6 on 8psi with a similar sized turbo and a zex 59300 cam isn't making 215whp.
Old Sep 21, 2005 | 05:51 PM
1point5CRX's Avatar
Default Re: 13.8 d15b7 (SOHC_MShue)
whats the afr @ wot? total timing?
Old Sep 22, 2005 | 03:53 AM
Default Re: 13.8 d15b7 (1point5CRX)
in uber my fuel enrich was set at 103 which gave me 12.5-13.1 afr...my timing was .70 per pound of boost...red line at 7500 rpms...with the si cam stock cam in motor started dieng after 5700....and yes that power was made on 14b with airport gas... 2.5 inch charge pipes....b18 throttle body also...so what you dont believe when i get a chance to post the dyno and slip i will but for all those rockin d's they know what these motors are capable of and each one is different and each setup....and your right about the motor probably not going to last long like that also...my street tune is with same fuel setup but .80 retard.....and my friends z6 with 14b, no cam, same timing and fuel...same IM is pushing more than me....so i guess your tune must have sucked with a cam and all too...**** zerodaze made 230 off a b7/z6mini-me14b....its all in the tune...
Old Sep 22, 2005 | 04:16 AM
TURBO DC2's Avatar
damn i've gained alot of respect for the D recently.. who would've thought
Old Sep 22, 2005 | 04:24 AM
1point5CRX's Avatar
Default Re: (slammed_gsr)
its alittle lean imo but i hope it holds together for ya. i like 14b's but im sticking to my t3 super60, hope to have dyno numbers deep into the 2's if not 300.
btw, what fuel is that, airport gas?
Old Sep 22, 2005 | 04:51 AM
Default Re: (1point5CRX)
its around 114octane
Old Sep 22, 2005 | 11:20 AM
Tad's Avatar
Tad
didnt he say he was runing 9psi not 8..
