HELP!!! APEXI FULL AUTO TURBO TIMER WIRING?!?
Old Sep 19, 2005 | 01:16 PM
turbotime's Avatar
Default HELP!!! APEXI FULL AUTO TURBO TIMER WIRING?!?
AHH I have an apexi full auto trubo timer but whatever harnesses were on it have been cut off(its used).
Can someone please give me the wire colors and what they go to??
Thanks- this is urgent!!!
Old Sep 19, 2005 | 01:36 PM
turbotime's Avatar
pls help!
Old Sep 19, 2005 | 02:06 PM
turbotime's Avatar
bump, need to know wehre the four wires that are supposed to be in the harness go (my harness got cut off....)
Old Sep 19, 2005 | 02:14 PM
turbotime's Avatar
found this:
red - 12v
blue - ACC
green - ON
black - ground
that right?
Old Sep 19, 2005 | 02:30 PM
no2unenolife's Avatar
Default Re: (turbotime)
Old Sep 19, 2005 | 05:05 PM
dualknuttz1's Avatar
Default Re: (no2unenolife)
OK this is direct from the APEXI manual:
Red: 12 V+ Constant
Blue: IG2 Output
Green: IG1 Output
White: O2 Sensor off ECU
Black: Ground (use ECU Ground if using O2 sensor)
Gray: Parking Brake Switch
Hope this helps
Old Sep 19, 2005 | 06:28 PM
turbotime's Avatar
perfect! tanks so much dual!
Old Oct 3, 2005 | 08:06 AM
OshkyCiv23's Avatar
Great info..
I was in the same boat... and this solved mine as well!
Old Nov 15, 2005 | 08:46 AM
R6E6I6D's Avatar
Default Re: (OshkyCiv23)
cool thanks a bunch, they dont make a harness for mine..
sireg6
Feb 9, 2007 09:38 PM
98teg
Oct 8, 2003 01:34 PM
BlackB18CTeg
Aug 10, 2003 06:03 PM
nerdsports
Apr 24, 2003 11:36 AM
cam0693
Oct 14, 2002 05:56 PM
