How much boost?
Old Sep 19, 2005 | 05:57 PM
AZNracerx1989's Avatar
Default How much boost?
This is the setup:
Integra LS 2001
t3 turbonetics
currently at 4.5 psi
stock fuel rail
stock fuel pump
stock fuel injectors
stock fuel pressure regulator
12:1 FMU
can I turn up the boost to 7 psi safely? or do i need fuel pump like the revhard kit?
Old Sep 19, 2005 | 05:58 PM
1boostedcivic's Avatar
Default Re: How much boost? (AZNracerx1989)
i would get an inline and an intank if u plan on skimping there bro.
Old Sep 19, 2005 | 06:00 PM
u need both inline and intank?
Old Sep 19, 2005 | 06:16 PM
on G2IC's site, he says stock injecotrs will fail if over 6 psi... so i think I can safetly turn it up to 6 psi..
but do i need to buy fuel pump and inline fuel pump?
Old Sep 19, 2005 | 06:40 PM
Revhard and Drag turbos come with high flow fuel pump and FMU... and they set at 7 psi...
so that means if i get inline pump or intank pump then i can set to 7 psi?
Old Sep 20, 2005 | 05:17 AM
Electron_LS-Vtec's Avatar
Do Not skimp when it comes to the fuel system. The stock injectors wont hold up running 100% duity cycles all the time. And when they cant flow any more you r afr go to **** and you detonate and blow your motor. Just get a walbro 255 and some damn DSM injectors and call it a day. and besides the point 1psi isnt going to do much for you.... good luck
Old Sep 20, 2005 | 05:45 PM
a guy is selling me an MSD inline fuel pump for cheap... should I get it???
will bigger injectors work the same with FMU?
Old Sep 21, 2005 | 06:37 PM
notanotherSC61's Avatar
Inline fuel pumps suck and just starve your stock pump. And eventually the stock pump shells out. JUst spend the 90 bucks on a walbro and call it done. Very easy install.
Old Sep 22, 2005 | 06:31 PM
so will I be able to push 7 psi when I get a fuel pump?
Old Sep 22, 2005 | 07:25 PM
StolenTeg's Avatar
intank pump, 550cc injector, and a good EMS(hondata, aem, neptune, uberdata)
Old Sep 22, 2005 | 10:18 PM
hondaxsimike's Avatar
Default Re: How much boost? (StolenTeg)
the LS motor has the potential to run about 12 psi max, safely with a good tune. DSM injectors and a walboro 255 in tank pump will get you closer to this mark.
Old Sep 23, 2005 | 10:44 AM
wantboost's Avatar
Who is Mr Robot?
Default Re: How much boost? (hondaxsimike)
first off ditch the fmu and get something like uberdata or crome, then come talk to us about upping the boost
Old Sep 23, 2005 | 11:28 AM
ramrod's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaxsimike &raquo;</TD></TR><TR><TD CLASS="quote">the LS motor has the potential to run about 12 psi max, safely with a good tune. </TD></TR></TABLE>
hm.. you might want to check out the LS-T thread. might blow your mind
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">first off ditch the fmu and get something like uberdata or crome, then come talk to us about upping the boost</TD></TR></TABLE>
:tu:
AZNracerx1989
Sep 18, 2005 08:21 PM
TEG777
May 17, 2005 12:22 PM
1tyme
Oct 22, 2002 12:36 PM
red civic standard
Oct 10, 2002 07:47 AM
HybridCoupe
Jul 6, 2002 04:44 AM
