problems with GT30R and GT2871R
Old Sep 20, 2005 | 06:39 AM
bht72's Avatar
Default problems with GT30R and GT2871R
hello,
my problem is ,that 2 turbos will be broked after a few miles(3000-4000).allways the part in the middle (CHRA!!??) will be damaged.
now my question is.have someone the same problems.i drive in the cars 14-18 psi.
i take the oil for the turbo from the oil pressure switch at the back side.
do some one know how much pressure must go to the turbo and how much oil must go thru the GT ..R turbo in one minute.
someone say that the pressure must be only between 2- 3.9 psi!?
i have the normal oil pressure from the engine to the turbo.is it to much?
i some hondas the GT..R turbos works perfekt until now ,but in two off them i have this problems.
sorry for my bad english.i come from germany.but i hope some people understand it.
ralf
Old Sep 20, 2005 | 06:48 AM
Tinker219's Avatar
Default Re: problems with GT30R and GT2871R (bht72)
first, are you sure youre getting TOO much oil?
If you are, try and find a .030" restrictor; several places sell them to fit the GT turbos.
I have over 15,000 miles on my 30/71R with no problems; and come to think of it, no restrictor either.
Make sure your oil return line is nice and straight, no dips below the oil pan bung.
Old Sep 20, 2005 | 06:51 AM
tony1's Avatar
Double check your oil feed line. I had a bunch of problems on 1 car. The engine had good oil pressure, but the line was clogged. When it was originally assembled, the teflon on the inside was rolled over into the hole and was blocking oil flow. It's not likely that you'll damage anything other than the seals in the turbo with too much oil, you probably don't have enough. Put a pressure gauge on the end of the turbo oil feed line.
Old Sep 20, 2005 | 07:02 AM
wantboost's Avatar
Who is Mr Robot?
Default Re: problems with GT30R and GT2871R (tony1)
you ahve to run the water lines to the turbo, i spoke with numerous garrett engineers about this. because of the full stainless steel bearing section (as opposed to ceramic) the waterl ines must be run because the bearings retain more heat and will cause oil breakdown if not properly cooled.
Old Sep 20, 2005 | 07:04 AM
Tinker219's Avatar
Default Re: problems with GT30R and GT2871R (wantboost)
yes yes yes! All of our turbos now come packaged with a sticker that says,"MUST RUN WATER LINES. IF NOT, THE BEARINGS <U>WILL</U> FAIL!". So, water lines hooked up?
And yes, double check your oil feed line, thats what I was getting at by my comment of making sure you have TOO much oil...
Old Sep 20, 2005 | 07:07 AM
LostSolVTEC's Avatar
Default Re: problems with GT30R and GT2871R (Tinker219)
i've seen so many set ups with the the GT-R turbos with no water lines run to them.... i just makes me sad and want to give the turbo the home it deserves.... cough cough my engine bay cough cough....
Old Sep 20, 2005 | 07:13 AM
wantboost's Avatar
Who is Mr Robot?
Default Re: problems with GT30R and GT2871R (LostSolVTEC)
my money goes to premature bearing failure due to lack of proper cooling (i.e water lines)
Old Sep 21, 2005 | 08:05 AM
bht72's Avatar
hello,
i have the water lines at the turbo.i cant believe that some one make the turbo without water lines.we her e i germany have no speed limit at the highway.i tune up hondas with turbo for other people.and all cars must run the full speed.when i check the oil line to the turbo,i have enough oil.it comes out of the line like a flood.
and at the oil return line it comes only a little bit out .i think about 3 oz (0,1 liter) in a minute.so i think this is not enough.but what can i do at this moment.what is then wrong with the CHRA from the GT..R .in much other cars it comes more oil out of the oil return line.i think about 10-15 oz (0,3-0,5 liter).in this cars the turbo runs perfekt.
Old Sep 23, 2005 | 05:09 PM
6shootahorsenamedtrigga's Avatar
hey is ur bung on the oil pan high enough? could be causing oil to back up into the turbo..but yeah are u running the restrictor in the feed line like what they said in previous posts? u need that with gt turbos
Old Sep 23, 2005 | 05:23 PM
eg:R's Avatar
i thought all gt model turbos come with oil pressure restructor built in. do they??
Old Sep 23, 2005 | 07:48 PM
Default Re: (eg:R)
actually i think they do,,cuz my 3071 thats not installed has one and i called precision and they said thats what it is
greasemonkee
Aug 25, 2007 03:46 PM
Dominick331
Apr 5, 2006 02:13 PM
b18c198
Jun 8, 2005 04:58 AM
b16ahybrid
Jun 6, 2003 11:52 AM
