external wastegate spring ???
Old Sep 15, 2005 | 05:46 PM
adamsjm5's Avatar
Default external wastegate spring ???
If you have a wastegate with a 7psi spring in it and want to run more boost, do you have to buy a new spring, or can you raise the boost by using a manual boost controller to raise the boost?
Old Sep 15, 2005 | 06:18 PM
vtec.dc2's Avatar
Default Re: external wastegate spring ??? (adamsjm5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adamsjm5 &raquo;</TD></TR><TR><TD CLASS="quote">If you have a wastegate with a 7psi spring in it and want to run more boost, do you have to buy a new spring, or can you raise the boost by using a manual boost controller to raise the boost?</TD></TR></TABLE>
you can do it either way, MBC would be cheaper but i would get EBC (electronic boost controller) that way you can adjust settings inside the car, and better EBC will allow for several settings, gear/speed based control to improve traction or overboost protection (my favorite and it works!), plus peaknhold readings.. from what i read you shouldn't go more than double psi level so in your case i would guess no more than 14psi but i'm not too sure about that one.
slowhonduh93
May 20, 2007 09:34 PM
yusoslo
Jul 12, 2003 08:01 PM
Screamer
Mar 29, 2003 08:00 PM
shingles
Jan 24, 2003 01:58 AM
vtec.dc2
Dec 28, 2002 08:03 AM
