turbo on a 01 prelude
Old Sep 15, 2005 | 02:50 PM
SilverPanda's Avatar
Default turbo on a 01 prelude
so im thinking about going turbo on my prelude. i know im going to get a t3 turbo and im looking on this site to buy it http://www.turbocalculator.com/sale-garrett.php. im just not sure about the other stuff. such as what compresser trim i should get and A/R and if i need an internal or external wastegate. i know you guys know a lot more about this than me. any help would be appreciated.
Old Sep 16, 2005 | 09:00 AM
Default Re: turbo on a 01 prelude (vtech22)
bump
Old Sep 16, 2005 | 11:51 AM
bump for some answers
Old Sep 16, 2005 | 02:25 PM
nerdsports's Avatar
i've heard some bad stuff about that website in particular.
do some research before buying from them.
also. you should look at other turbo prelude setups. see what they run as far as wastegates, turbo sizes, etc.
no one is gonna explain everything to you, so i suggest using the search feature a lot.
Good Luck! and honestly, a lot of things that i know now about forced induction was gathered here on honda-tech or on homemadeturbo.com. All it takes is some reading.
Old Sep 16, 2005 | 02:52 PM
Default Re: (nerdsports)
sorry just looking for a little help. but thanks anyways.
Old Sep 16, 2005 | 02:58 PM
jdmlude01's Avatar
Default Re: (vtech22)
What are your hp goals? What do you currently have on your motor?
Old Sep 16, 2005 | 03:55 PM
Default Re: (jdmlude01)
ummm im looking for about 250 whp at the most. but right now i have an injen cai and megan headers. so not that much.
Old Sep 16, 2005 | 04:43 PM
TheShodan's Avatar
Moderator
The Prelude is an excellent platform in order to turbo provided that the right parts and tuning are used. going cheap or finding other roundabout ways to just save cost can do just that: COST in the long run. Find out a bit on what you want to do with the car (street/strip, fun street predator, circuit course, or drag strip) and find out what you want to get out from it.
Start to then look at the kind of budget that you have, or can obtain over time. Don't skimp out on the important things to retain reliability. Be careful.... The H22A is a bit delicate in the sleeves, so it can't take the high cylinder pressures as the other B-Series Motors. Here is an example (I've Probably shown this before a couple of times)
Stock H22A Turbo, custom kit
550cc RC Injectors
AEM Pulley (Car was originally NA)
AEM FPR
TIAL BOV w/ TIAL .6bar wastegate
Custom Garrett T3/T04E STC "Red Pill" Turbo Ceramic coated and polished
298whp @ 245ft/lbs at 8.5psi on 2.5" Downpipe and 2.5" exhaust using E-manage on stock ECU. even kept A/C and Power Steering
Modified by TheShodan at 1:58 AM 9/17/2005
Old Sep 16, 2005 | 05:15 PM
Default Re: (TheShodan)
see i want exactly the same setup as that prelude. what is the setup?
Old Sep 16, 2005 | 08:52 PM
wantboost's Avatar
Who is Mr Robot?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmlude01 &raquo;</TD></TR><TR><TD CLASS="quote">What are your hp goals? What do you currently have on your motor?</TD></TR></TABLE>
stay away from turbocalculator. they are a company of ssac and they sell the same **** turbos, none of them are garretts.... they use turbo xs, stone racing and all of that other bullshit
Old Sep 16, 2005 | 10:57 PM
Default Re: (wantboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">stay away from turbocalculator. they are a company of ssac and they sell the same **** turbos, none of them are garretts.... they use turbo xs, stone racing and all of that other bullshit</TD></TR></TABLE>
thanks for the info. i was just wondering if you could run down the whole setup of that red prelude?
Old Sep 16, 2005 | 11:10 PM
booja's Avatar
theres my setup... block is built with a gt35e turbo and 800cc inj. 3" DP and exh. full custom setup tuned with hondata
i made 492whp on 17psi
Old Sep 16, 2005 | 11:41 PM
Default Re: (booja)
anyone heard good/bad things about this site http://www.extremeturbo.com?
Old Sep 17, 2005 | 12:55 AM
planeman01's Avatar
i'd stay away from turbocalculator.com...i was going to go through them untill i did a search...
Old Sep 17, 2005 | 05:32 AM
TheShodan's Avatar
Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtech22 &raquo;</TD></TR><TR><TD CLASS="quote">
thanks for the info. i was just wondering if you could run down the whole setup of that red prelude?</TD></TR></TABLE>
No Problem:
STC T3/T04E "Red Pill" 4 bolt .63 A/R Exhaust housing
Rev-Hard Ceramic coated log Manifold
TIAL 50mm BOV
TIAL 38mm wastegate .4 bar
Spearco 26x3x6 Bar & plate intercooler
2.5" exhaust (upgrading to Kteller 3")
Rev-Hard/Spoolin' performance/ custom intercooler piping
2.5" Downpipe
RC550cc Injectors
OBDII Stock ECU w/ E-Manage Piggyback (Those that don't like it, or only "heard" about how the system works don't waste your typing skills to comment )
Greddy Profec B Spec II Boost controller
Greddy Turbo Timer
18" Volk GT-C wheels.
298whp@24ft/lbs at 8.2psi
Old Sep 17, 2005 | 08:24 AM
2point2's Avatar
How was spool-up with the long 'hot pipe'?
I'm curious because mine had to be quite long as well..
Old Sep 17, 2005 | 09:36 AM
TheShodan's Avatar
Moderator
Default Re: (2point2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2point2 &raquo;</TD></TR><TR><TD CLASS="quote">How was spool-up with the long 'hot pipe'?
I'm curious because mine had to be quite long as well..</TD></TR></TABLE>
Spool was just fine. No issues whatsoever
Old Sep 17, 2005 | 10:16 AM
umm the shodan just wondering if you could tell me where i could get a STC T3/T04E "Red Pill" 4 bolt .63 A/R Exhaust housing and a Rev-Hard Ceramic coated log Manifold? i cant find those anywhere and i'd like to use that turbo and manifold for my setup
Old Sep 17, 2005 | 01:22 PM
does anyone know if this is an alright turbo for my hp goals? REV HARD T3/T4E TURBO on this website http://racespecialists.com/Mer...e=TRB
Old Sep 17, 2005 | 01:24 PM
and i was also wondering if you could tell me what a wastegate does?
Old Sep 17, 2005 | 03:54 PM
bump
Old Sep 17, 2005 | 04:49 PM
Oyvind Ryeng's Avatar
All of your questions will be awnsered by hitting the search button. Seriously. It's all been covered multiple times.
Old Sep 17, 2005 | 05:12 PM
sharkcohen's Avatar
Default Re: (Oyvind Ryeng)
Nothing wrong with E-manage, it's a fine platform, especially for those that for whatever reason must keep the stock ECU in the car.
Old Sep 17, 2005 | 05:24 PM
flip1199's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtech22 &raquo;</TD></TR><TR><TD CLASS="quote">umm the shodan just wondering if you could tell me where i could get a STC T3/T04E "Red Pill" 4 bolt .63 A/R Exhaust housing and a Rev-Hard Ceramic coated log Manifold? i cant find those anywhere and i'd like to use that turbo and manifold for my setup</TD></TR></TABLE>
i believe theshodan sells that turbo. pm him. as for the revhard mani, just buy the many anywhere and then send it out to get coated.
Old Sep 17, 2005 | 08:17 PM
Pullig's Avatar
Default Re: (flip1199)
you should run a t3/t4 hybrid on that h22 t3 SEEMS a little small for that engine
