Proof of gains from turbo rebuild (another stock ignition dyno)
1 Post
Well, I previously posted the dyno chart from my personal car about a month ago. When I did that dyno, I simply unplugged my boost controller (which, with my current controller, causes maximum boost). That's the blue line.
The red line is the same car (same setup) with everything the same except that the turbo was rebuilt and the car was retuned. The boost was also controlled with the boost controller maxxed out, so the new red lines are on less boost (I would guess 2-3psi, but its hard to tell because of the large difference between gauge pressure and absolute pressure here).
The new pull goes to around 9.5k, I would have liked to pulled it to 10k or further; I'll think try that next time out
Setup: very simple
Stock bore b18c, LS crank
CP pistons, full-race rods
Old-school (I mean really old, but still holding strong) full-race prostreet manifold
t3/t67, .63 hotside
3" full-race DP, 4" JouleSpeed exhaust
The only differences:
1) rebuilt turbo
2) removed the MSD 7al in place of a 100% stock ignition system with nothing but a blaster 3 coil wired directly to the distributor (I was motivated by Jeff Evans' most recent posts to try it out)
3) retuned by me
It feels so much smoother on the stock ignition system with the blaster coil too, which I thought was very strange. The tune changes were more drastic than I expected them to be.
Setup: very simple
t3/t67, .63 hotside
1) rebuilt turbo
3) retuned by me
Location: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Re: Proof of gains from turbo rebuild (HybridHatch88)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridHatch88 »</TD></TR><TR><TD CLASS="quote"> Congrats. </TD></TR></TABLE>
Sickness!
Sickness!
Re: Proof of gains from turbo rebuild (orangerex04)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by orangerex04 »</TD></TR><TR><TD CLASS="quote">nice power. must be fun</TD></TR></TABLE>
Re: (servion)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by servion »</TD></TR><TR><TD CLASS="quote">I'm still using the oldschool greddy profec-b (not the spec 2, its the original one)
I still remember that one, gangster!!
Re: Proof of gains from turbo rebuild (servion)
What type of bearing was used for your rebuild on the turbo? I know if you have a FR turbo they state they use the 360 degree thrust bearing. I hear it was a bit off balanced and looks like your spool time is better...
