HX35
Old Sep 17, 2005 | 11:44 AM
SwappedTURBOegg's Avatar
Default HX35
so what are everyones thoughts on the 12cm HX35?
my setup
hondata s200 W/ 3 bar
1000cc injectors
vextor X intakemanifold
stock B16 head with GSR cams
ARP headstuds OEM head gasket
LS block GSR crank 9.5 CP pistons and egal rods *GSR lingth*
costom turbomanifold W/ 38 mm wastgate 3" DP
JRC 8" core
I hope to see full boost at 4800 and make somewhere around 500HP with C16 at 25 PSI *hopefuly*
I have no experance with this turbo..if anyone has any imput it wold be much appreciatied.
Old Sep 17, 2005 | 12:03 PM
KeyserSoze's Avatar
Default Re: HX35 (SwappedTURBOegg)
Do a search for holset, there is a holset thread with lots of support.
Here is the comp map for that turbo, the hx35 is the green plot:
Old Sep 17, 2005 | 12:39 PM
Default Re: HX35 (KeyserSoze)
I have its verry similar to the 60-1
Old Sep 17, 2005 | 12:40 PM
powerofdreams8's Avatar
Search around, here is a whole thread. https://honda-tech.com/zerothread?id=1225182
I think the HX35 will be well suited to your needs given your setup.
Old Sep 17, 2005 | 01:00 PM
KeyserSoze's Avatar
Default Re: HX35 (powerofdreams8)
You could also use the hy35, at the right pressure ratio the hy35 will flow mad amounts of air and hp is partly a product of the airflow. Theoretically ~725cfm will get you close to 500hp. The hy35 will flow up to ~880cfm (prolly more than you will ever want) and have a lower boost threshold (it will start producing boost earlier) than the hx35.
Traction might be an issue, but I am lucky enough to have an aem ems so I can use the traction control option.
Old Sep 17, 2005 | 05:02 PM
drumking15's Avatar
better than 60-1 imho... for yet another hx35
full boost for me 15psi = 4000-4200 w/ a ls/vtec w/ 3" open dp
full boost 15psi w/ stock tiny 1.8" exh = 5k
so your gonna spool up a hair better than you want...and once in boost...the jump from say 7-15 is so miniscule...id say maybe a 200rpm ramp up speed....
Old Sep 17, 2005 | 07:02 PM
Default Re: (drumking15)
awesoem im stoked! i picked up my pistons today, 9.01 and im going to keep the ls crank.
Old Sep 18, 2005 | 06:38 AM
drumking15's Avatar
Default Re: (SwappedTURBOegg)
running the same thing
jdragon1974
19
Jun 1, 2013 07:37 AM
FastGSRCoupe
Dec 17, 2012 05:57 AM
Slava.
Mar 8, 2006 01:38 PM
methodz55
May 7, 2005 01:12 AM
WH0R3nEF9
Mar 13, 2005 11:43 AM
