LS Turbo Help!!
Old Sep 16, 2005 | 07:56 PM
southpole12's Avatar
Default LS Turbo Help!!
I just got my turbo put in my integra 2 weeks ago. Its an Ls and here is what i got
-3" charge pipe to 2" ic piping
-t3/t4 turbonetics turbo
-small front mount intercooler
-255 Walbro fuel pump
-35mm Tial wastegate
-3" downpipe
-Blitz BOV
-450cc DSM injectors
-Hondata S200
*************Now here's the problem*************
I had it tuned 2 times and when i go to hit full throttle and even half it breaks up ALOT??? Even more when i go to hit full throttle, am i flooding out??? Leaning out?? I dont know whats going on and its very slugish? I had NGK 5 heat range plugs in on first tune and it wasnt that bad but still broke up alot... than i put in NGK 6 heat range spark plugs and its worse but that was after the second tune?? Can someone give me some guidance here?? Id appreciate it. Thanks
Old Sep 17, 2005 | 12:04 AM
slither's Avatar
What gap are you running on the plugs?
Old Sep 17, 2005 | 12:57 AM
planeman01's Avatar
gap on the plugs should be .028-.032, sounds like your ingnition...i've HEARD that ls ignitions are weak? can someone back me up on this? how much boost?
Old Sep 17, 2005 | 08:16 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: (planeman01)
run Vpower NGK's but 5 and 6 u dont need get 8's.....
how many lbs u pushing? gap should be between 20-30....
also u might want to change teh 3" charge pipe to a 2.5....u are losing power there
Old Sep 17, 2005 | 08:28 AM
Default Re: (Snoflake)
im only running 7 lbs.... i gappped them to 30 but the gap was wrong at first. than i took them out and regapped them and it still is running messed up. I think it might be the wires possibly
Old Sep 17, 2005 | 08:36 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: (southpole12)
yea 30 is good try out the 8's and try someone else's wires see if that doe teh trick...check your cap adn rotor to ensure it isnt messed up as well
Old Sep 17, 2005 | 08:38 AM
ok, i dont have 8's i have 7's those should work right? and ill try to borrow some wires before i buy them, hopefully this works
Old Sep 17, 2005 | 08:41 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
yea 7's are kool......
Old Sep 17, 2005 | 08:43 AM
ok good, how my WHP should i have on 7lbs and torque?
Old Sep 17, 2005 | 11:46 PM
Default Re: LS Turbo Help!! (southpole12)
anyone have anymore feedback
Old Sep 18, 2005 | 06:14 AM
JDM_EH2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by southpole12 &raquo;</TD></TR><TR><TD CLASS="quote">ok good, how my WHP should i have on 7lbs and torque?</TD></TR></TABLE>
Around 200whp...depending on your turbo size
Old Sep 19, 2005 | 05:33 PM
problem fixed... car moves now... im happy. thanks for the info.
92integra-R
Feb 26, 2007 05:02 PM
92integra-R
Feb 26, 2007 04:56 PM
silverb18
Mar 31, 2004 08:08 PM
Chip398193
Mar 18, 2002 12:31 AM
