What ECU can I use to Boost my Civic
A lot of people seem to be using the P28 ECU but is there any other ECU that would work without having to be modded. Mind you this is going into a 2000 Civic Si with the P2T ECU.
Re: What ECU can I use to Boost my Civic (c_hladilek)
just about any vtec obd1 ecu will work. p28s are the most common and usally reasonably priced, they dont come with any knock boards that you would disable anyway. you will need a obd2-obd1 conversion harness.
Re: What ECU can I use to Boost my Civic (N20civicB18)
I don't know alot about the different ECU's are the V-tec OBD1 Would the P30 or the P75 ECU's possibly work as well?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by c_hladilek »</TD></TR><TR><TD CLASS="quote">I don't know alot about the different ECU's are the V-tec OBD1 Would the P30 or the P75 ECU's possibly work as well?</TD></TR></TABLE>
No...P75 is a non-vtec ECU
