.84 ar on a stock h22
Old Sep 19, 2005 | 02:33 PM
nylude's Avatar
Default .84 ar on a stock h22
I have a stock h22 and am trying to uptain at least 350-390whp will i be able to obtain this hp leavel with this turbo. turbo is a garrett t3/t4 with a .84a/r on the hot side and .60 ar on compressor side. the fuel will be controled by rc 750cc injectors a walbro 255lph pump. ems will be aem. i don't have any springs in the head so i will have to keep the stock limit of 8000rpms.
thanks for your advise
Old Sep 19, 2005 | 03:08 PM
213374U's Avatar
0x5359-0055
Community Builder
Default Re: .84 ar on a stock h22 (nylude)
Won't do it for long without dropping compression
Old Sep 19, 2005 | 04:25 PM
nylude's Avatar
Default Re: .84 ar on a stock h22 (Vt4cPwn35)
around what rpm do you think the turbo will see full boost. (10psi)
Old Sep 19, 2005 | 04:39 PM
93hatched_projekt's Avatar
Sounds good, 350 whp isnt that hard to obtain with a h22. I'm currently running a sc61 with a .63 ar/56 trim and spools at 3k and hits full boost around 3800rpm @ 8psi. I havent hit the dyno but it ran a 12.1 @ 118 mph on a street tune. I think the .84 ar is overboard, so i'd look into a .63 ar. With that much compression/displacement it' makes for real fast spool.
Modified by 93hatched_projekt at 2:00 AM 9/20/2005
Old Sep 19, 2005 | 07:11 PM
dennis's Avatar
I have .82 hot side on my f22 and it's lag city. I'd prefer a .63 if I can find a deal on one. Power comes on strong, but it just takes a while to spool up. 10psi might be around 5k+. H22 might spool a lil better, but I wouldn't imagine a ton better.
Old Sep 19, 2005 | 10:14 PM
b16hybridsol's Avatar
Default Re: .84 ar on a stock h22 (dennis)
full 9psi at 4500rpms on a jdm h22 with a 60-1 .82ar, stage 5 wheel, 2.5"dp
Old Sep 20, 2005 | 04:22 AM
11seclude's Avatar
Default Re: .84 ar on a stock h22 (b16hybridsol)
does garrett even make a .84 a/r in a t3 housing??
I think that turbo is way to big for a stock h22. the car going to be slow because first off it's stock second you going to have to pull alot of timming because you going to want to keep pressure off the pistons,third you got to run on the rich side like 11.0-11.5 a/r. since the motor is stock,forth you cant rev higher because no springs and retainers.
many people say you can boost a stock car it's all in the tune. but most of them boosting b-series hondas witch is to me stronger than a h22 in stock form.
Modified by 11seclude at 8:37 AM 9/20/2005
Old Sep 20, 2005 | 10:55 AM
notanotherSC61's Avatar
Default Re: .84 ar on a stock h22 (11seclude)
These seem like ridiculous #'s. First that turbo is huge and you won't spool it unless your running at large rpms, so it will suck on the street. 2) No matter how good the tune is the pistons will be smoked, because at these power goals there is no such thing as a conservative tune. 3) Did someone give you some false asumption that these numbers would be attainable with stock internals and be safe. If you use this turbo an obtain and power it wont be useful hp.
Old Sep 20, 2005 | 11:00 AM
h22 civic's Avatar
Default Re: .84 ar on a stock h22 (notanotherSC61)
lotto lag on that 22 stock with a ar 82 probally in the nehibohood of 5000 rpm better get a 63
Old Sep 20, 2005 | 11:55 AM
nylude's Avatar
Default Re: .84 ar on a stock h22 (h22 civic)
well i bought the turbo from a shop here in ny called juiners. i was told that this turbo wont spool until like 3rd gear from someone at garrett turbo but this is after i got the turbo. the guys at the shop said that this turbo will spool around 4k. on the exhaust housing inlet there is 2 holes like a seperator for the exhaust gas to go into the turbo.
Old Sep 20, 2005 | 02:54 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nylude &raquo;</TD></TR><TR><TD CLASS="quote">well i bought the turbo from a shop here in ny called juiners. i was told that this turbo wont spool until like 3rd gear from someone at garrett turbo but this is after i got the turbo. the guys at the shop said that this turbo will spool around 4k. on the exhaust housing inlet there is 2 holes like a seperator for the exhaust gas to go into the turbo.</TD></TR></TABLE>
ouch, thats a t4 housing which is even worse, divided tang mightgive you a slight more chance but that turbo will suck ona stock h22
Old Sep 20, 2005 | 05:05 PM
nylude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16hybridsol &raquo;</TD></TR><TR><TD CLASS="quote">
ouch, thats a t4 housing which is even worse, divided tang mightgive you a slight more chance but that turbo will suck ona stock h22</TD></TR></TABLE>
so why are they trying to sell me a t3 manifold then. they said something about it being a european housing is there a such a thing??? i paid these guys 700.00 for this turbo!!! what must i do now, I cant get my money back!
Modified by nylude at 6:23 PM 9/20/2005
Old Sep 20, 2005 | 05:28 PM
GaRn's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nylude &raquo;</TD></TR><TR><TD CLASS="quote">so why are they trying to sell me a t3 manifold then. they said something about it being a european housing is there a such a thing??? i paid these guys 700.00 for this turbo!!! what must i do now, I cant get my money back!
Modified by nylude at 6:23 PM 9/20/2005</TD></TR></TABLE>
man, post a pic of this turbo, I hope its not an XS power hehe..
Old Sep 20, 2005 | 05:39 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: .84 ar on a stock h22 (GaRn)
european housing is a t4 housing with a t3 flange. the turbo you bought is a master power (only real masterpowers ahve this option) youll be fine
Old Sep 20, 2005 | 05:40 PM
wantboost's Avatar
Who is Mr Robot?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vt4cPwn35 &raquo;</TD></TR><TR><TD CLASS="quote">Won't do it for long without dropping compression </TD></TR></TABLE>
what the hell are you tlaking about? this is the second dumb ******* post ive seen you make. as long as its tuned well and he keeps boost levels modest it should run forever
Old Sep 20, 2005 | 05:41 PM
igy's Avatar
igy
Yep, there is such a thing as a AR.84 EURO small inlet hsg(T3 flange). You are probably looking at 10psi a little closer to 5k even with the divided hsg and a manifold built for it. I ran an AR. 84 Ptrim on a stock automatic B16 motor and made 7psi at around 5500rpm's. I am currently running an AR.70 O trim and make 7psi before 5k.
Old Sep 20, 2005 | 06:58 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: .84 ar on a stock h22 (igy)
well, hes got a much longer stroke and bigger bore.
with a properly designed manifold and all he should see boost quite early. some of the master powers use floating ball bvearings from what i understand
Old Sep 21, 2005 | 06:32 PM
Default Re: .84 ar on a stock h22 (wantboost)
All this post does is beat around the bush that this isn't the proper turbo to use but will work. Great so dump 5-6K on a turbo set up that is not efficient. Why not do it right the first time instead of going through turbo after turbo. There are many people who spec turbo applications for your specific set up.
tunerraceteam
Oct 13, 2008 12:18 PM
jdmbb6-t
Aug 3, 2006 12:32 PM
kagee
Apr 5, 2006 05:22 PM
DS1
Oct 23, 2002 10:56 AM
