Tueno spewing oil all over the place.......Help maybe seals or turbo
Turbo spewing oil all over the place.......Help maybe seals or turbo
I have a t3 67 trim turbo and the other cday i thought that the drain was wrong so i changed it around but the same thing the turbo spews oil all over my block. what could that be and how bad could it be? it has only done it twice or three times....the other day when i chamged my oil it took 5 qts of oil to fill but the type r pan is like 4 qts.. could that be some of the problem?
Re: Turbo spewing oil all over the place.......Help maybe seals or turbo (88_DX)
i did it in the shop and i put 4 qts in and started teh car to run the oil throughout the motor and it was low so added more....its my first turboed car so i figured it was the turbo.. any help?
Re: Turbo spewing oil all over the place.......Help maybe seals or turbo (jh)
you might have to much oil and its not draining back properly... Did you add oil and check it while it wa running?
