GM 3 bar MAP sensor question.
Old Sep 17, 2005 | 09:06 AM
O16581724 5 2 5's Avatar
Default GM 3 bar MAP sensor question.
Since the search feature has been down for the past hour, i guess i'll post. I'm looking into this MAP http://cgi.ebay.com/ebaymotors...ZWD1V
What's required to make that work? The holes and wiring look different.
Old Sep 17, 2005 | 09:41 AM
Default Re: GM 3 bar MAP sensor question. (O16581724 5 2 5)
Okay, i stumbled upon information that the MAP just hangs around hooked to a vacuum source and the stock MAP, or a block off plate is used to block the hole. How is wiring done?
Old Sep 17, 2005 | 09:42 AM
boostedcivicsir's Avatar
Mr. Badwrench
http://www.hondata.com/tech3barmap.html
hope that helps
Old Sep 17, 2005 | 09:54 AM
Default Re: GM 3 bar MAP sensor question. (boostedcivicsir)
It does, thanks.
Old Sep 17, 2005 | 11:38 AM
agrn93ls's Avatar
i got a new 3 bar last night from a friend and it looks identical, it has that white sticker and all, i checked my part # and it is correct, can you get the P/N from the guy it should be a 12223861
Old Sep 19, 2005 | 06:16 AM
petersayarath's Avatar
kool post
The DX Rex
Sep 18, 2009 08:56 PM
KRWTEK1
May 28, 2007 12:32 AM
Smashback
Jan 27, 2003 03:33 AM
philo
Dec 3, 2002 08:37 AM
Loco Honkey
Nov 13, 2002 04:17 PM
