What Affects Idle Mostly?
Old Sep 16, 2005 | 10:21 AM
litterbox's Avatar
I am a (Trial User) Army
Default What Affects Idle Mostly?
On high hp FI cars what affects idle mostly? Is it injector size? Assuming this is a stock motor (stock cams) what else would affect idle?
Old Sep 16, 2005 | 10:23 AM
tgreaves's Avatar
Default Re: What Affects Idle Mostly? (litterbox)
Air/fuel ratio affects it..
Old Sep 16, 2005 | 10:24 AM
litterbox's Avatar
Default Re: What Affects Idle Mostly? (tgreaves)
Solely?
Old Sep 16, 2005 | 10:48 AM
91dxcrx's Avatar
water temp, especially on boosted hondas. my friends car wouldnt idle worth a **** until the water temp got to normal operating temp
Old Sep 16, 2005 | 10:50 AM
tgreaves's Avatar
Default Re: What Affects Idle Mostly? (91dxcrx)
Just about everything affect the idle.. If you tell us what problem your having it would make it eaiser to help you..
Old Sep 16, 2005 | 11:03 AM
litterbox's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgreaves &raquo;</TD></TR><TR><TD CLASS="quote">Just about everything affect the idle.. If you tell us what problem your having it would make it eaiser to help you..</TD></TR></TABLE>No problem.
I finished my k24 swap into my EG a few weeks ago and I'm just now starting to research FI because that's the route I will be heading in next summer.
Basically I'm looking for a setup that will be very streetable on low-medium boost (9-10psi).
This was just one question that popped into my mind, that's all.
Old Sep 16, 2005 | 11:06 AM
91dxcrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by litterbox &raquo;</TD></TR><TR><TD CLASS="quote">No problem.
This was just one question that popped into my mind, that's all.</TD></TR></TABLE>
with a good tune idle shouldnt be a problem
Old Sep 16, 2005 | 11:35 AM
SOHC_MShue's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91dxcrx &raquo;</TD></TR><TR><TD CLASS="quote">water temp, especially on boosted hondas. my friends car wouldnt idle worth a **** until the water temp got to normal operating temp</TD></TR></TABLE>
maybe he needed to adjust the ECT correction. My car used to run like **** until warm until they came out with ECT corrections for uber.
EGIan
10
Feb 11, 2009 07:52 PM
jdmgeezer
Dec 9, 2007 11:23 PM
Pele
Feb 9, 2003 01:01 AM
