boost gauge install
Old Sep 17, 2005 | 10:06 AM
ferio 95's Avatar
Default boost gauge install
Ok this is a rather n00b question and for some reason the search thign isnt working (server issues)
so to the point. im trying to install a boost gauge. its an autometer and it uses the nylon tubing. well my problem is how do i connect it to the rubber vacuum lines? it sounds like a easy thing to do but the nylon doesnt work with the T's. is there some special way of doing this or am i just really not getting it.
Old Sep 17, 2005 | 10:13 AM
null.'s Avatar
Default Re: boost gauge install (ferio 95)
connect a silicone/rubber hose over the tee and the nylon so that they connect, ghetto but it works
Old Sep 17, 2005 | 10:18 AM
ferio 95's Avatar
Default Re: boost gauge install (eg6junkie)
whats going to keep it from blowing out the rubber tho? i assume just using zipties on it like i did all the other lines would work just fine
Old Sep 18, 2005 | 03:36 PM
ferio 95's Avatar
anyone else
Old Sep 18, 2005 | 04:10 PM
smoovy's Avatar
I ran the nylon/plastic hose down the silicone hose about 12" and I ziptied it about every 2-3" and connect silicone hose to T-fitting. works good and doesn't blow off. remember to use zip ties though.
Old Sep 18, 2005 | 04:18 PM
eg crunkmonster's Avatar
Default Re: boost gauge install (smoovy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smoovy &raquo;</TD></TR><TR><TD CLASS="quote">I ran the nylon/plastic hose down the silicone hose about 12" and I ziptied it about every 2-3" and connect silicone hose to T-fitting. works good and doesn't blow off. remember to use zip ties though.</TD></TR></TABLE>
yup thats how i have mine, i put the hose from the boost gauge into the rubber vacuum hose about a foot and zip tied it, no problems or anything with leaks
Old Sep 18, 2005 | 06:49 PM
213374U's Avatar
0x5359-0055
Community Builder
Default Re: boost gauge install (eg cookiemonster)
I'm not following..... am I the only one who had no problems?!?!?!
R6E6I6D
Nov 21, 2005 06:47 PM
EVOCELICA
May 3, 2004 07:27 PM
boostdB16a
Jul 28, 2003 11:48 AM
dualknuttz1
May 7, 2003 05:59 AM
HotHB
Nov 21, 2002 08:17 AM
