biggest shot of nos on 1.6 SOHC
I was just wondering. I was planning on changing the rotating assembly and jucing the motor I want to hit it with big shot with a fogger system . Just wanted some feed back . Thanks Tom
Re: biggest shot of nos on 1.6 SOHC (TSM)
if youre talking about a bottom end rebuild, then a wet kit will suit your needs better. with good rods and forged pistons you should be able to run 150 shot no prob. and maybe more than that with good tuning
what kind of setup u got on that sohc? i could tell u with stock motor, u could probably go witha 60 shot single fogger wet system. built motor could handle alot more tho... depending on your setup
Re: (TSM)
l would look into a 2 stage setup to help with traction. A single fogger first stage followed by a direct port second stage would be nice. 100hp on the first stage followed by another 125 on the second would be nutty.
Re: (TSM)
you need to check out some of my threads about the juice.
harv
spraying 400 direct port pro race fogger...out of the hole? spinning plum to the
330 and still running 7.12 @ 104.....w/1.52 60'....only thing taken out of the car was the p/s seat and back seat....bottle pressure was 1300...
harv
