dsm injector compatability
Old Dec 21, 2005 | 11:16 AM
AJxr's Avatar
Default dsm injector compatability
i have a 90 civic si, stock d16a6 and im putting together a turbo set up. what i need to know is will 1g dsm 450cc injectors plug into the stock injector plugs or will i have to get the plugs from the dsm and wire them in?
heard they plug right in but i need someone to confirm it.
thanks
Old Dec 21, 2005 | 12:41 PM
TheShodan's Avatar
Moderator
Default Re: dsm injector compatability (AJxr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AJxr &raquo;</TD></TR><TR><TD CLASS="quote">i have a 90 civic si, stock d16a6 and im putting together a turbo set up. what i need to know is will 1g dsm 450cc injectors plug into the stock injector plugs or will i have to get the plugs from the dsm and wire them in?
thanks </TD></TR></TABLE>
You will need the OBD0 clips for the DSM injectors. Because they are peak and hold, you'll still need a resistor box for the difference of impedence.
Old Dec 21, 2005 | 12:45 PM
EJ1 wilcox's Avatar
Default Re: dsm injector compatability (TheShodan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheShodan &raquo;</TD></TR><TR><TD CLASS="quote">You will need the OBD0 clips for the DSM injectors. Because they are peak and hold, you'll still need a resistor box for the difference of impedence.</TD></TR></TABLE>
The 90 Si already has a resistor box, so you don't need that. As far as the injector clips go, I'm almost certain they plug right in, if anything you might have to modify them a bit to fit, but I'm pretty sure you don't even have to do that.
Old Dec 21, 2005 | 12:47 PM
AbitAvenger's Avatar
Default Re: dsm injector compatability (EJ1 wilcox)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ1 wilcox &raquo;</TD></TR><TR><TD CLASS="quote">The 90 Si already has a resistor box, so you don't need that. As far as the injector clips go, I'm almost certain they plug right in, if anything you might have to modify them a bit to fit, but I'm pretty sure you don't even have to do that. </TD></TR></TABLE>
You can either get the dsm clips, or use the stock clips and modify the injectors. Theres just a small tab you need to "shave down" with a razor blade. Took me like 2 minutes to do all four of mine
BTW I have an obd1 d16z6
Old Dec 21, 2005 | 12:51 PM
AJxr's Avatar
Default Re: dsm injector compatability (AbitAvenger)
thanks for the help! exactly what i needed to know
jdmdikk
23
Jan 26, 2009 01:19 PM
motoman358
Feb 21, 2006 09:00 AM
AJxr
13
Dec 26, 2005 07:21 AM
allmotorsircrx
Feb 11, 2004 08:16 PM
Pinhead
Apr 16, 2002 07:30 PM
